Sponsored by: CARiD
p0128 error code 2010 e550
Old Dec 27, 2024 | 02:38 PM
miky2001's Avatar
2010 E550
the check engine light came on and autozone says its code P0128 2010 e550
they says i need a new thermostat
i drove the car and it drives just fine,
the temperature got up to 87 C after short ride, so i dont really understand the problem???
i think this is a job i could probably do myself
autozone wants $217 for the part, but i notice it can be had for a lot less elsewhere
any advice on where to get one would be greatly appreciated.
thanks in advance
Old Dec 27, 2024 | 02:50 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
thanks in advance
Your best interest is to buy trusted genuine parts, not the cheapest available look-alike thermostat. It will serve you well.
Old Dec 27, 2024 | 03:32 PM
TimC300's Avatar
I was searching around and see others that had that code and it was not due to a faulty thermostat.
Im not saying that its not your thermostat, just saying there may be other reasons. One was due to a low battery. Have you had the battery tested lately, how old is it?
The thermostat should open around 100 degrees C. When you start the car and start driving does the temp slowly rise to over 80 C, then around 90 C it should drop a little which is the thermostat opening.
If it takes awhile to get up to temp and you dont notice a small drop in the temp around 90 C then the thermostat may be stuck open, or faulty o-ring in there.
Im not sure which engine you have. On my M272 the Mercedes brand thermostat is stamped Wahler, so if I had to replace it i would just buy the Wahler brand which is less expensive than Mercedes branded.
Old Jan 13, 2025 | 06:07 PM
miky2001's Avatar
2010 E550
i bought the wahler, installed it, and the car is running fine and the temp gauge is moving as it should so i think i fixed it. used a little over a gallon of new antifreeze
not such a difficult job witht the wife holding a flash light aand the wrench to release the temsion on the belt to get the pulley back on
the check engine light is still lit tho?
how do i get that tuned off?
thanks again
Old Jan 13, 2025 | 07:16 PM
thanks again
Congrats on completing this engine repair
Now, use your scanner to reset the ECU calling the CEL... hopefully whatever fault will stay off
couple drive cycles may deactivate fault condition.
Old Jan 13, 2025 | 09:35 PM
miky2001's Avatar
2010 E550
i have driven it back and forth here and there a few times, the light is staying on, i dont have a scanner.
is there any other way to turn off the light?
Old Jan 13, 2025 | 10:04 PM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
Get a scanner if you plan to keep the car!
Old Jan 13, 2025 | 10:16 PM
Autozone is advertising "free code reading"... if you flash a twenty... you could get more traction ??
Old Jan 13, 2025 | 11:01 PM
miky2001's Avatar
2010 E550
they will read the code, but they are not allowed to get rid of it. i tried o reillys too... i guess i gotta go ask that guy i know since its not turning itself off....
Old Jan 14, 2025 | 01:16 PM
ChuangTzu's Avatar
Amazon Amazon
Old Jan 14, 2025 | 01:25 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
And that scanner is $40 off the $169 price for only a few more days. Get one. You won't be sorry and you will save money by having one.
Old Jan 14, 2025 | 01:45 PM
Launch scanner
that scanner is the best reader for your car!!
It can email free comprehensive pdf reports to help diagnose remotely
Old Jan 14, 2025 | 05:46 PM
ChuangTzu's Avatar
This^
You will save much more in the long run.
