Parking Brake Not Holding
It's sad when dealer techs are not allowed to fix basic systems. I remember MB dearler repair of my failed sunroof was like pulling teeth with idiots.
Rear parking brakes use independent brake shoes with an sel-adjusting ratchet mechanism.
Try setting and releasing PkgBrake 5 or 6 times to cut down on aggravations...
is more angled a movement than a straight nice disc brake type piston movement.
One thing I noticed, since drum brake ( parking brake ) is enclosed , the rusty friction surface of the inner disc brake DRUM section, hampered good parking brake bite.
Because it is enclosed, it rarely get maintained as in rust and dust control, making its working capability even less.
Just remember that drum brake/parking brake is a servo action, meaning the tire has to spin at least 180 degrees to get final good bite where the brake shoe then "expanded enough " and grip well.
Just in case user is comparing/expecting it to instant stop of disc brake or newer stand alone electric parking brake using stand alone caliper or solenoid assisted but using rear disc brake
own caliper as parking brake.
I told you already in post #9.
"Just remember that drum brake/parking brake is a servo action, meaning the tire has to spin at least 180 degrees to get final good bite where the brake shoe then "expanded enough " and grip well."
Read here : https://www.akebono-brake.com/englis...nner%20surface.
My SL uses drum-type parking brakes but they are electric and the car doesn’t budge an inch.
