Multiple Warning Instrument Cluster Lights Came On
I have a 2011 Mercedes E350 and one day I started it up and got a whole bunch of warning lights that I will include a picture of. The car was able to start up and I am able to move around and what not but I haven't been driving it as I am scared that it will damage the car further. I am not able to move my seats around, the headlights don't work, the ambient air temperature sensor doesn't work as the fan to cool the radiator is spinning at high RPMS and the instrument cluster can't get a temperature reading of outside, and I can't read the tire pressure.
I have a Carsoft M2 diagnostic tool and ran it, and I got some fault code readings but I am not too sure how to properly assess them as I am a bit of novice when it comes to these things. I will also include pictures of the readings as well. I suspect I could be dealing with an electrical issue potentially? I have seen times where water enters the cabin from the rain which is where my suspicions derive from.
Any help or suggestions would be much appreciated. I'm trying to revive my baby lmao. Thanks!
Selecting "CENTRAL GATEWAY" on my Diagnostic Tool.
Selecting "INSTRUMENT CLUSTER" on my Diagnostic Tool.
- move my seats around,
- the headlights don't work,
- the ambient air temperature sensor doesn't work
- the radiator fan is on high RPMS
the instrument cluster can't get a temperature reading of outside,- I can't read the tire pressure.
The worst is the supersonic fan regardless of ECU working fine. It can drain your battery dead.
Since we know issue started with the swampy connections....
-1- deal with water entry leak first to stop it
-2- next fix electrical damages...
> Based on reported failed items, I am going to guess this is taking place on driver side.
> Peal back the carpet to expose/dry footwell area and doorsill entry with CAN bus bars.
> inspect fuses in relation to supersonic fan. Its is not getting a PWM Clock signal from ECU, despite it working all right
The Water and Ice in the Footwell
A bit of an update; I found water and ice in the footwell (I live on the East Coast with freezing temps so that why I have ice). I was able to clean and dry it all up, and cleaned up the ground connections with some sand paper. However, I'm still dealing with the same electrical issue.
How should I proceed further. Any tips or recommendations are welcomed. Thanks!
door sill bus bars
They likely need attention and tiny connectors as well...
What does your scanner report??
Any missing VIP modules from swampy CAN disruption?
Confirm you disconnected batteries while cleaning your GND Posts, right?
-- You want to go there with a schematic to know what CAN branch your dealing with.
You'll be really good at it.
So just to confirm, there are bus bars within that plastic component that I should check and clean out? Again I assumed that it was just a plastic container holding and protecting all of the wires.
Driver side is wet.... (passenger side also: not likely both. MB prefers seamping driver side first).
unlikely both sides are wet at once unless it's high tide
Use scanner to assess what modules are disrupted from what bus bar being iced up.
Help Beware : bus-bars slots receive specific modules.
Meaning don't remove all connectors without first numbering their individual position 1234667890. This explains why some slots are empty.
It will work if scrambled but the bus-bar troubleshooting game is played differently.
Here's how: you disconnect the module you want off the bus by reading its position on the schematic -!If uou remove all, then... nothing works so long story short you dont want to not know "who's who".
Number first!!
Colors are indicative of bus name: CAN-B : BRN/RED deals with doors.
You can't mix buses members together.
When in doubt take pictures of what goes where!!
Bus-bar are worthless parts replace if oxidized.
Fragile connectors must be preserved using oily WD40 to help not oxidize into loose connection nightmare.
Expect bus scanning to be partially disabled with buses shorted out by green crusties.... exactly what leads to pulling your hair madly.
You pull-up connection to remove CAN short-circuits unril the last vonnector helps restore running chassis.
Bus Bar
Bus Bar
Corroded Wire
Update: It was the two Bus Bars that was causing the issue. There was corrosion on the pins in the can bus and some on the wire plugs. I bought two new Bars from the Mercedes dealership, plugged them in, and the car works just fine no more errors anymore.
However, I am concerned about the corrosion. I didn't clean the corrosion off of the wires, however the car still works posting no errors. Should I clean off the wires or will my car be okay?
Bus Bar
Bus Bar
Corroded Wire
What you do with that... is entirely up to you. Know that it can help or hurt the corrosion meaning DISABLE use of your car: no crank, no doors, you name it.
Usually oil protect against oxidation but when the tini-tiny connectors are loose the NO Contact.
You may want to cut out connectors and solder wires or use twist nuts. All same volors together so two bunches... kindo' easy job.
https://www.aircraftspruce.com/menus...nals_butt.html
Once it's compromised: it keeps rolling downhill.
We help make good things simple!!
Try to stay proactive with maintenance. MB are well built for timely service.
Consider all your fluids... they need not be forgotten.
Prevent vibrating undersized conductors (hard to locate failure!) - Zip-tie or tape bundles.
