Sponsored by: CARiD
Porsche Macan Wheels on E550 Cabriolet?
Old Jan 21, 2025 | 05:17 PM
sjay's Avatar
Corvette
Apologies if this is a stupid post but I am clueless when it comes to wheels and hoping others with experience can chime in. I have a 2011 E550 cabriolet. Stock wheels - 18x8 (235/40/18) FRONT and 18x8.5 (255/35/18) REAR. the wheels are the 6 spoke design which I believe have a 45-49? MM offset.
I have been looking at 5 spoke design wheels and came across a local ad for Porsche Macan 5 spoke wheels. Bolt Pattern is the same 5x112, 18x8 and 18x9 wheels with 21+ mm offset.
I love the design of the wheels and was wondering if these would work for my car or not. Any insight is much appreciated.
Old Jan 21, 2025 | 06:07 PM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
Any time you purchase a set of wheels, you need to look at three things , the bolt patterns, center bore size and the wheels offsets
The center bore is the wheel hole that fits on to the wheel hub extension, the part that the wheel sits on and where you put the center caps on
they do make hub centric rings (that fits inside the wheel hole and changes the CB size ) making the wheels fit but if not sized correctly you would always have vibrations
Find out the CB sizes and see if the Macon wheels are compatible or not?
also the correct offsets- the bigger the number, the more the wheel sits in and, the smaller the number the more it’s pushed out
hope that helps
Old Jan 21, 2025 | 06:48 PM
chassis's Avatar
2017 GLE350 4MATIC
Macan hub pilot dia = 64.46mm per google.
MB 66.56 per google. If true the Macan wheels won’t fit on the hub without an adapter and longer wheel screws.
Old Jan 21, 2025 | 07:34 PM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
Try any of an assortment of MB 5-spoke wheels that look almost identical. Such as the ones on this car:
https://bringatrailer.com/listing/20...abriolet-13-2/
Old Jan 21, 2025 | 09:09 PM
sjay's Avatar
Corvette
I had looked into this seller confirmed they would fit (66.5) and my research online (porsche forums) and websites suggested it was 66.5 as well. (see for example: 2020 Porsche Macan - Wheel & Tire Sizes, PCD, Offset and Rims specs | Wheel-Size.com)
Old Jan 21, 2025 | 09:10 PM
sjay's Avatar
Corvette
I have been looking for these wheels but cannot find anything that is in good shape - all damaged and curbrashed to no end.... I have seen cls wheels and S-class wheels but mostly 19/20's im trying to stick to 18's for ride quality.
Old Jan 21, 2025 | 09:24 PM
ChuangTzu's Avatar
Well, you can buy them new...
Old Jan 21, 2025 | 09:27 PM
ChuangTzu's Avatar
These are fixable:
https://www.ebay.com/itm/267130919535
