Level Calibration
Replace by pair or all at once.
(even non-Airmatic Facelift steel coil springs feature a height sensor on the rear axle, driver side!! to dial the LED headlights height)
If it is not down then you have a sensor reading issue, i.e., your sensor arms probably are broken, and the reading does not change when you press that f10 trying to raise the car. If the car raises up, that you should be able to see or at least measure, then the Airmatic works pumping air in the spring and the problem is sensor is not seeing the height change.
If the car does not raise up and the compressor runs you have either leaking air spring or the solenoid valve does not work for the right rear spring.
Airmatic malfunction means the air compressor is not able to raise the car in certain time and it shuts down for protection of the compressor. This means either the compressor is bad or the air spring has a big air leak or the solenoid valve for that spring does not open (very rare problem).
My guess is you have so a big leak that the compressor cannot supply enough air volume to raise car up and you probably had this problem for some time and did not act on it until the leak got so bad you get malfunction that does not clear, right?
Can your computer do a proper diagnosis of the system? If not, find someone with xentry to check pressures and switch function. That you replaced the front but not the back would lead me to the bag first imo. I chased something similar on a used e55 that was slightly low on the right rear but never sagged. After 20k miles the car sagged after sitting a few days and it was time to replace the shocks. Once I replaced the bags, all was dead on and it calibrated perfectly.
It is the S-class that has only one sensor for the rear axle, which I also have.
Rear springs are cheap and easy to change, I did mine.
I have since had lots of trouble with Arnott struts on my S550 and cannot trust their quality anymore for the struts but the rear springs I would still buy.
op, have you checked the sensors yet? Or unplugged, cleaned and tried again?
