Sponsored by: CARiD
rear springs E 350
Old Feb 23, 2025 | 09:19 AM
lowufo777's Avatar
2013 E 350 4 matic
rear springs E 350
Hello
can anyone inform me of the correct springs to use in our E 350 ? stripe colors ?. any videos available on how to replace them? its a standard 350
thanks in advance!
Old Feb 23, 2025 | 10:14 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Depends on your suspension, do you have 485 luxury or 677 sport? my '13 sport had green and red stripes, but its loaded as in luxury 3 package. you can order from FCP Euro by specifying which suspension you have, I got mine for 67 dollars a piece from them, I jacked up the car by the rear differential, compressed the springs and they came right out, compressed the new ones and popped them back in, check upper and lower mounting plates, top is plastic, bottom is metal, I replaced these as well. Make sure you have springs properly seated in both top and bottom mounts.
Old Feb 23, 2025 | 11:13 AM
lowufo777's Avatar
2013 E 350 4 matic
THANKS FOR THE REPLY ! HOW CAN i TELL IF IT IS A 485 OR 677 ? IS THERE A TAG SOMEWHERE ?
Old Feb 23, 2025 | 11:28 AM
lowufo777's Avatar
2013 E 350 4 matic
how do I determine the difference?
Old Feb 23, 2025 | 06:14 PM
lowufo777's Avatar
2013 E 350 4 matic
I used the vin # on this web site .it says I have a luxury model . I don't know of any other luxury 3 ? package ?
Old Feb 24, 2025 | 08:44 AM
W205C43PFL's Avatar
Yes luxury means the luxury styling package some mb models with this package also have different suspension tuning.
Old Feb 24, 2025 | 11:02 AM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
If the W212 is like the W211, you probably need to look at your current springs and check the color stripes, then you also need to check the thickness of your spring pads, which is indicated by a number of "nubs".
Old Feb 24, 2025 | 12:42 PM
No, but you can run your VIN number to find out which suspension you have
Old Feb 24, 2025 | 12:45 PM
if your car has the sport ground effects all around , its a sport, if it doesn't you have the luxury which is 485 most likely, there is a rare raised option past that one, but highly unlikely you have that.
Old Feb 24, 2025 | 12:47 PM
So if you've verified you have 485 luxury suspension, you need luxury springs, the sport suspension is an inch lower so shorter springs than the luxury,
Old Feb 24, 2025 | 12:50 PM
ChuangTzu's Avatar
When I got springs for my W211, the dealer couldn't tell me what springs and pads to order based on my VIN. It wasn't determined only by the type of suspension setup I had, but also by the other options which add weight and change the weight distribution. I had to check the spring band colors and spring pad nubs first and then they gave me the part numbers for these.
Is this not the case on the W212?
Old Feb 24, 2025 | 12:52 PM
The different spring colors designate how heavy the car is with options, there are I believe 14 different spring options based on engine size and other features on the car, there are three levels of luxury package, most cars are luxury one, some are luxury two, luxury three is extremely rare, in 2013 it came with heated steering wheel and headlight washers, a few small things also like cargo netting and all weather floor mats, etc.
Old Feb 24, 2025 | 05:33 PM
Yes, two main categories by length,One is progressive the other linear for Sport and Luxury, then subgroups of each based on engine size and options, That amounts to I believe 7 options for the front, factory springs and some aftermarkets are designated by two color bands on the springs. so yes, if you have a red stripe and green stripe as stock, you should replace it with the same, my luxury has blue and pink i think.
