Sponsored by: CARiD
How to open / pry back cover abs esp
Old Feb 26, 2025 | 08:17 PM
prakersa's Avatar
Which should i pry, above metal or below metal ?
Tks
Old Feb 26, 2025 | 09:09 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
opening cover
You want to free the top from the sticky bottom:
seam area between top/bottom
I used an exacto/scalpel blade to slice up silicone sealant.
Old Feb 27, 2025 | 12:10 AM
prakersa's Avatar
I tried use hot gun blower, but still no luck
Old Feb 27, 2025 | 12:34 AM
its not glued
its high-temp RTV
Old Feb 27, 2025 | 05:24 AM
prakersa's Avatar
its not glued
its high-temp RTV
Is this my abs looks like ?
Old Feb 27, 2025 | 06:25 AM
Nope, I don't think so!
highly integrated circuit
highly integrated ceramic circuit
This nice circuit is too modern and reliable.
MY'14 W212 uses solderless pins.
Old Feb 28, 2025 | 06:59 PM
prakersa's Avatar
Now what 👀
Old Mar 1, 2025 | 01:54 AM
S-Prihadi's Avatar
Since your ABS module is already opened up, can you kindly take lots of close up pictures for our database.
The higher the resolution the better.
I never expected it look like that.
I was assuming it will look like Cali's unit, but Cali's unit is ESP Premium, below :
I wonder how mine looks like inside. I checked my ABS sticker it has ESP PLUS while yours is ESP Basis
Old Mar 1, 2025 | 02:23 AM
Now what 👀
Bosch did something special for basic module version.
​​​​​​This is a double decker: a two circuit boards sandwich.
the white board looks fine without loose pins
Under that top layer is another circuit board where everything and 4x MOSFETS connect to.
-- How does the other side looks like... any access?
If you can't gain access to poor connections, you won't be able to fix them and may need to source a replacement control.
You need to find the poor junction causing your issue. Inspect everything closely with magnifying lens.
Old Mar 1, 2025 | 02:46 AM
S-Prihadi's Avatar
The other side of the board #2 ( assumed ) is in post #1 , below :
So if double board, 1st to 2nd layer can't be acessed with ease
Assumed 1st layer board, better resolution, he gave me in PM
Old Mar 1, 2025 | 03:17 AM
Good catch MS!
It looks like there are failure opportunities found on the coil side - It gives you a chance for a fix.
There is a hidden PCB with couple capacitors sandwiched under the solenoids.
VALVE SIDE:
each poor junction need to be made reliable
TOP SIDE:
top side has a few exposed junctions
POWER MOSFETS:
4x Mosfet need good solders
mosfet are fastened to metal and pins doldered to separate PCB... this means solders are holding the PCB = vibration stress! Inspect closely.
Old Mar 1, 2025 | 06:58 AM
prakersa's Avatar
I wish mine like cali's,
This basis has an aluminium wire which difficult to solder.
It' s a bounding method
Old Mar 1, 2025 | 07:03 AM
prakersa's Avatar
Good catch MS!
VALVE SIDE:
TOP SIDE:
POWER MOSFETS:
I guest this is the main caused....
Old Mar 1, 2025 | 09:04 AM
prakersa's Avatar
Mo
Most common failed from the aluminium wires...
Some say it's ok to replace with common cable or wire
Old Mar 1, 2025 | 12:23 PM
I think you'll find the bounding wires to be of good quality. They are welded, unlikely to come loose. "Never say never" double-check each one is secured. Not a primary concern here.
The solenoid side has some nasty looking junctions...
Old Mar 19, 2025 | 11:33 PM
S-Prihadi's Avatar
So, how is the final outcome ?
Soldered broken soldering already....and ABS OK now ?
Who did the soldering ?
