Sponsored by: CARiD
Car not shifting out of park
Old Apr 18, 2025 | 09:52 AM
bobb00's Avatar
Hello, I have a 2014 E350 that was running perfectly and yesterday the battery died because I left something open and ever since I jump started it this morning it won't shift into anything and says "Do not shift gears visit dealer".
I have a P179A77 code that says "The Redundancy System for DIRECT SELECT Was Activated The Commanded Position Cannot Be Reached." and P179D00 "The Redundancy System for DIRECT SELECT Was Activated".
I would appreciate your guys feedback on this, thanks.
Old Apr 18, 2025 | 02:10 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
POWERING UP
Let's try to save you a big stack $$$$ by not replacing your ISM Module. It has done its job textbook perfect under low voltage.... it is not faulty.
Jumping your flat battery really was the wrong thing to do...
  1. charge MAIN + AUX with a smart charger
  2. then reboot chassis (batt off)
  3. then clear all modules faults
  4. then press brake pedal and shift PRND with ignition-On.
Right now chassis has gone marginal in poor voltage, uncluding AUX has gone low temporarily supplying heavy loads.
> Charge batts and refresh status should resume prior condition. Use a smart charger to protect from stock battery drain.
FYI: flat lead-acid batteries are dead batteries regardless of date code. Replace both when convenient.
Why... the systems in these cars are proven to be sensitive to voltage variations. It best to at least avoid extra straining.
Old Apr 18, 2025 | 05:15 PM
bobb00's Avatar
Ok thank you, I also have C073200 "No CAN Message Was Received From Control Unit 'Engine'. and C054200 "The CAN Message From Control Unit 'A80(Intelligent Serrvo Module for DIRECT SELECT)' Is Faulty.
Can those steps you just gave still help? Even with these additional codes'
Old Apr 18, 2025 | 06:03 PM
yes, I'd say so.
Feel free to try other ways perhaps more suitable to reach your goals.
All of these faults likely caused by super low voltage near 8 Volts.
Old Apr 18, 2025 | 08:42 PM
JettaRed's Avatar
Veteran: Army
Fix one thing at a time. This was caused by an electrical issue -- dead battery. When that happens, all sorts of codes would be thrown.
I wouldn't even attempt to charge the battery. Replace it. Then clear all your codes. (What scanner are you using?)
Get a CTEK battery maintainer and put it on the dead battery and see if you can revive it. Then you will have a backup. But dead batteries tend to stay that way.
Old Apr 19, 2025 | 12:22 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Please follow the advice by @CaliBenzDriver and @JettaRed , but most importantly after it is fixed is the summary conclusion: do NOT jump these cars unless you are extremely familiar with their nuisances. It can be a very expensive experience. Always charge the battery with a charger, and the car is NOT a charger.
Fingers crossed it is just the side effect of low voltage.
Old Apr 19, 2025 | 01:16 AM
Raysglk350's Avatar
Before anything check your fuse 13 in the engine compartment it's a 7.5 fuse my blew replaced it now it shifts again
Old Apr 19, 2025 | 03:24 AM
While you're checking fuses... check the AUX Batt fuse.
AUX 7.5A fuse blows once batt has being emptied out.
With a bad fuse, even a new AUX won't get any charge voltage.
Old Apr 20, 2025 | 08:02 AM
bobb00's Avatar
I tried all the steps, none worked. Under the data stream of the module it says the module isn't personalized or initialized. Does it need to be re-initialized to fix? Or can something else be causing it to say that?
Old Apr 20, 2025 | 08:04 AM
JCM_MB's Avatar
If I recall correctly, mine says the same on the E. I would recheck later today
Old Apr 20, 2025 | 09:35 AM
bobb00's Avatar
Thank you
Old Apr 20, 2025 | 01:59 PM
The car was was fine before you jumped it... it can't be too far from ok now!!
Can you read scanner data from ISM: PRND Status ?
What are both battery voltage with engine running??
Old Apr 21, 2025 | 12:48 PM
bobb00's Avatar
I cannot find the PRND Status on my data stream, but I will go through everything again and double check. However, when the car is running the battery voltage for the MAIN Battery is around 14.8v and the AUX is around 12.8v.
Old Apr 21, 2025 | 02:11 PM
bobb00's Avatar
Old Apr 21, 2025 | 02:12 PM
bobb00's Avatar
That is everything on my data stream for ISM
Old Apr 21, 2025 | 04:01 PM
Great!
It looks like your AUX is not powered.
that's what keeps your ISM in limp-mode.
check the AUX nearby charge fuse: red 7.5A.
report your progress towards free repair!
Old Apr 21, 2025 | 04:11 PM
You can read this clearly in plain English :
Your ISM is forcing Limp-mode.
Let's iron out power supply issue by AUX
clear faults
you should be ok
Old Apr 21, 2025 | 04:21 PM
bobb00's Avatar
I checked the 7.5a fuse that's on the AUX battery and it's not blown and I just replaced it with a new one anyways.
Old Apr 21, 2025 | 04:23 PM
bobb00's Avatar
The AUX holds at 12.8v whether the engine is off or on, is the AUX battery bad? Also, If you can please elaborate on what "Let's iron out power supply issue by AUX" means please.
I really appreciate it a lot for your help diagnosing this as well. Thanks
Old Apr 21, 2025 | 04:33 PM
bobb00's Avatar
Also, I know about the batteries under the hood and in the trunk. However, I'm seeing online something about there being a small one under the steering wheel housing? Can you confirm if that's true?
Old Apr 21, 2025 | 04:38 PM
AUX Batt is supplied through a 7.5Amp fuse that blows under various conditions.
AUX should get chassis voltage with engine running... right now it's only shiwing 12.8... not near 14.88v like main batt.
AUX charge Fuse is the prime suspect.
Check it out !
Old Apr 21, 2025 | 04:54 PM
JCM_MB's Avatar
Here is my data stream from the ISM.
You can compare yours to mine, and realize the PERMANENT LIMP mode setting is different.
Can you please enter into the TCM module, and check the Driver Authorization entries?
On the AUX battery being at 12.8V, I am only certain mine will go to 14.7/8V for a few seconds after starting up, and winds back to 12.8V. I still have my LIN connected, @CaliBenzDriver that could be the difference. The "smart algo" may switch to 12.8V once the AUX passes the check.
Please check Fuse 88 (15A) in the RearSAM, and Fuse 16 (5A) in the FrontSAM
Old Apr 21, 2025 | 04:58 PM
EITHER / OR.. not both
AUX have two distinct incarnation:
tiny alarm size inside dashboard side
OR
Motorcycle size in the trunk for ECO feature.
I understand you are dealing with
MAIN in engine bay
AUX in the trunk
There's no 3rd battery...
Old Apr 21, 2025 | 05:11 PM
ISM
Hi JC, yes that makes sense.
It could be that supply side gets disconnected so AUX does not see chassis voltage all day long...
besides AUX monitoring circuit has a displayed fault which we are not seeing here...
Then how to get this good ISM back in gear:
1- clear faults
2- then... what causing ISM "limp mode" activation??
It seems to be responding to its CAN-C very well (not swamped) ✅
Old Apr 21, 2025 | 05:14 PM
JCM_MB's Avatar
besides AUX has a displayed fault which we are not seeing here...
1- clear faults
Either a DIRECT SELECT fuse is blown, or the Drive Authorization is failing to complete; therefore, no shifting is allowed. Not certain if his scanner is bi-directional to actuate from the shifter of the TCM module to Neutral.
