Sponsored by: CARiD
Serpentine belt diagram
Old May 6, 2025 | 04:44 PM
donny79's Avatar
e350
My belt fell off I’m trying to find the correct diagram online but I can’t find it …. Anyone know where I can get correct diagram??
Old May 6, 2025 | 04:48 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
what engine type/yr ??
Old May 6, 2025 | 04:50 PM
donny79's Avatar
e350
3.5 v6
Old May 6, 2025 | 05:00 PM
donny79's Avatar
e350
272.980
Old May 6, 2025 | 05:11 PM
272.980
How about
Old May 6, 2025 | 05:15 PM
Old tensioner is the killer of idlers & serpentine.
Do the complete kit at once.
Use a *CONTINENTAL* BELT.
Old May 6, 2025 | 07:02 PM
donny79's Avatar
e350
That video not same, mine different
Old May 6, 2025 | 07:11 PM
pls post a picture of your M272 so I can diagram the path to help
Old May 6, 2025 | 07:12 PM
donny79's Avatar
e350
It’s w212
Old May 6, 2025 | 10:32 PM
S-Prihadi's Avatar
See if the idler pulleys arrangement are the same on ur M272
https://benzbits.com/M272/BeltRouting.pdf
Old May 6, 2025 | 10:37 PM
donny79's Avatar
e350
No I have w212
Old May 6, 2025 | 10:45 PM
donny79's Avatar
e350
M276 engine I think I found it
Old May 6, 2025 | 10:46 PM
S-Prihadi's Avatar
Take a wide angle photo of your engine front.
A few photos left to right to make a panaromic view of all involved pulleys , will be good.
We can figure it out with above photos because some pulley/s is only allowed to receive the back side ( smooth) side of the belt, not the ribbed side.
Old May 6, 2025 | 10:47 PM
donny79's Avatar
e350
Ok I’ll do it tomorrow in daylight, thanks
Old May 6, 2025 | 10:50 PM
272 > 276
M276
M276- NA
this is with electric steering... no pump.
Old May 6, 2025 | 11:00 PM
donny79's Avatar
e350
No that’s not it
Old May 6, 2025 | 11:20 PM
donny79's Avatar
e350
WDDHF5GB4AA082600
thats my vin
Old May 6, 2025 | 11:44 PM
donny79's Avatar
e350
@S-Prihadi yes you were right that diagram you sent was it, I had to come outside because it was driving me nuts , that’s right one thank you
Old May 6, 2025 | 11:45 PM
S-Prihadi's Avatar
Old May 6, 2025 | 11:54 PM
S-Prihadi's Avatar
Wow, so many variations........
Old May 8, 2025 | 01:25 PM
donny79's Avatar
e350
Is this right placement for the belt on tensioner? I had it in the middle and when I started the car it moved to the end and I shut it off, is this normal place for it on the end like that?
Old May 8, 2025 | 01:50 PM
NOT BELT.... KIT
that section looks right.
Compare that you did follow the whole routing correctly, true?
Did you check idlers freeplay??
Specialy the one after your steering pump.
BTW the old tensioner NEEDS to get replaced else your new belt will be short lived. If you must drive like this... do not run A/C compressor to prevent slippage.
FYI : this is potentially unsafe repair as your steering pump runs from shared belt.
Loosing belt stops steering assist without warning. I've had that happen to me while turning so I can warn you about loosing steering.
Service requires a kit: [tensioner + idlers + belt] at once.
Besides inspect steering high pressure hose for active leak.
Old May 8, 2025 | 02:10 PM
donny79's Avatar
e350
Ya I did it pretty quick once I had diagram, new tensioner will be here Tuesday , I let it run for a while seems good to go I just don’t know if that belt to close to the edge, I had it lined up in the middle as it ran it moved to the edge…. Ya other day I was on real busy hwy right around a bend and I heard flapping , when I pulled over the belt was shredded, my tensioner I replaced 2 years ago the wheel had a slant and belt kept slipping I’m hoping I can drive this till new tensioner comes in
Old May 8, 2025 | 02:18 PM
don't discount the plastic idler pulleys with the dry bearings.
They actively guide the belt in position.
When idlers are wobbly... then belt is all over the place as you describe.
You need to inspect every unit for freeplay:
  1. ALT
  2. Water Pp
  3. Idler pulleys
  4. Steering Pp
  5. A/C compressor
  6. Main harmonic balancer
Main crankshaft pulley also designed to require replacement. It uses rubber that turns into chewing gum to wobble 1st class.
Old May 8, 2025 | 02:55 PM
donny79's Avatar
e350
It’s on correctly, belt in the grooves, no noises, I just wasn’t sure if belt was supposed to be on the edge like that, nothing wobbling or anything like that
