Sponsored by: CARiD
Do I have an AC issue?
Old May 20, 2025 | 05:39 PM
W205C43PFL's Avatar
Originally Posted by JCM_MB
The solenoid is what makes it variable. It allows the ECU to control the level of cooling at a fixed RPM even if the magnet is fully engaged.
I would need to record mine to compare to yours. To me, 1 C is border line freezing the evaporator, so it must be cooling well. Recall there a few sensors outside, and inside to keep the AC at the set temperature.
Thank you : )
Old May 20, 2025 | 09:49 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by prakersa
I don't know, because it looks work like conventional compressor, cut in and cut out. Do you think it suppose to work steady, since the compressor has solenoid?
your scaner shows degrees ....
now look at other PID's with your scanner:
compressor clutch
A/C pressure
control valve rate
Old May 20, 2025 | 10:24 PM
S-Prihadi's Avatar
My compressor cut out when temp reach 1C and cut in when 4-5C. Normal or abnormal? E300.2009 thanks
That is normal factory setting.
It is called HUMIDITY DEPENDENT setting.
Use your Launch to change it to FIXED 2C
Also change the radiator ( also condenser) fan speed "quietness" target to NO.
Old May 21, 2025 | 11:14 AM
W205C43PFL's Avatar
On a side note, on the topic of a/c so we were talking about nitrogen (I mean the liquid form) on the thread, I realized that is a good cooling agent to have when you don't use a/c (just kidding).
