Sponsored by: CARiD
Lowering Springs
Old Jun 2, 2025 | 02:56 PM
KrisJ's Avatar
Lowering Springs
Need Help!
recently lowered my W212 E350 CDI on H&R springs and as soon as I picked the car up it has a popping noise when you turn the wheel at parking speeds. New Top Mounts/Bearings were put on also. I have since taken them apart and replaced the Shims also and put different Top Mounts/Bearing make on but still the noise persists. This weekend I have changed the Shocks for new ones as the left side had blown and also put a 25mm drop Spring on instead of the 35mm H&R but again the noise continues. The Springs are all seated where they should be I just can’t work out why it is still popping on Turning. The noise sounds like it is coming from the top of the strut/bearings…. Any ideas? Love the way it looks don’t really want to have to admit defeat and put it back to stock 😩
Old Jun 2, 2025 | 04:42 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
pops
AWD or RWD?
Old Jun 2, 2025 | 04:48 PM
KrisJ's Avatar
It’s RWD, wished I’d left it alone now tbh!
Old Jun 2, 2025 | 04:59 PM
can you disconnect SB Links to rule that out ...
How about 2x BJ?
Old Jun 3, 2025 | 12:36 AM
S-Prihadi's Avatar
25mm lowering of your suspension is A LOT.
I advice you to not do it, you have upset your suspension geometry A LOT by lowering down by 25mm.
Some information good to know :
Old Jun 3, 2025 | 04:44 PM
key word... GEOMETRY
Outcome: custom looks + distressed tires
Old Jun 3, 2025 | 05:13 PM
brentif's Avatar
2016 e350 4matic Wagon
I second the idea of checking the sway bar end links. My wagon certainly more than 35mm lower than stock and I do not have any popping noises. The wagon is AWD, so I am not familiar with the differences in your front suspension. Did you have it aligned at a reputable shop that works with lowered vehicles on the regular? I did add some K-Mac camber kit to keep the rear in check and after that all four wheels are within all factory specs.
Old Jun 3, 2025 | 05:31 PM
Look at steering tie rods...
are they straight with rack?
are they at 40° angle with rack?
No toe adjustment can fix that setup.
Steering rack being far away from a neutral position is troublesome with suspension travel.
Hence zero travel fixed-suspensions holds toe angle.
