Sponsored by: CARiD
Question about Engine Mounts for Mercedes E250 W212 — Same Part Number for Both
Old Jul 11, 2025 | 05:57 AM
Spruze's Avatar
Mercedes E250 W212 Diesel- OM651
Hi everyone,
I recently purchased a pair of engine mounts for my 2014 Mercedes E250 W212 (Febi brand). I have a few concerns and would really appreciate your advice:
  1. Both mounts have the exact same part number, but they came in separate boxes. Shouldn’t there be a “LEFT” and “RIGHT” designation? There’s nothing written about left or right on either box or the mounts themselves.
  2. Are the mounts supposed to be identical, or are they usually different for each side on this model?
  3. I asked the shopkeeper, and he said it’s completely normal — that they use the same part number for both sides.
  4. I also tried searching the part number online, but I couldn’t find clear information regarding left/right fitment.
Should I keep these mounts, or do I need to return them and get different ones for each side?
Has anyone else faced this? Any guidance would be really helpful before I go ahead with the installation.
Thanks in advance!
Old Jul 11, 2025 | 01:05 PM
Pantomime's Avatar
2016 E350 Sport
I had my engine mounts replaced recently and they're the same; interchangeable.
Old Jul 11, 2025 | 01:08 PM
Spruze's Avatar
Then why do they have left and right mentioned on them?
Old Jul 11, 2025 | 01:24 PM
Pantomime's Avatar
2016 E350 Sport
Spruze, in your original question, you wrote, " There’s nothing written about left or right on either box or the mounts themselves." Then you asked, "Then why do they have left and right mentioned on them?" Seems your questions are contradictory! I recall mine did not specify right or left and mechanic who installed them had no problems.
Old Jul 11, 2025 | 01:31 PM
Spruze's Avatar
I am talking about other brands that have mentioned left and right like Lemforder. Why do some brands have it and why doesn’t Febi have it I meant. Which brand were yours?
Old Jul 11, 2025 | 01:51 PM
Pantomime's Avatar
2016 E350 Sport
I used Febi. I'm not sure why others show L and R.
Old Jul 11, 2025 | 01:57 PM
Spruze's Avatar
Can you please share the pictures of the mountings you installed if you have.
Old Jul 11, 2025 | 02:04 PM
Pantomime's Avatar
2016 E350 Sport
I got them from FCPEuro. I copied this from my account page:
SKU:FEB-29975FCP Euro ID:722686GTIN / UPC:04027816299752
Made in:Spain Quality:Aftermarket
OE Numbers
2042400917, 2042404317
MFG Numbers, [size=13px]29975[/size]
Old Jul 11, 2025 | 10:00 PM
S-Prihadi's Avatar
Must check EPC and your VIN.
Often both are different P/N , mine is and so is M276.9 3.5NA type W212 chassis code W212.059
M276.9 3.5NA engine. Same for both.
My E400 and a C200 W204 engine mounts P/N
BWT, Febi qualty I read is not so good. But since you already bought it, use it.
I stick to MB original mount.
Some information on engine mounts for your fun reading :
https://mbworld.org/forums/e-class-w...tear-down.html
Old Jul 11, 2025 | 11:21 PM
Spruze's Avatar
WDD2120036L035438
I am really confused and worried should I get mine installed or replace them with some other brand? Can you please confirm with the VIN that are they identical? Because I am sure the MB p/n are also different but in real do they really have a difference?
Old Jul 12, 2025 | 02:13 AM
S-Prihadi's Avatar
Originally Posted by Spruze
WDD2120036L035438
Here u go...... see different P/N for Left vs Right
So in India the MB cars ( unless true AMG ) is also locally assembled like in Indonesia ?
Get genuine MB mounts...... u will sleep well.
Old Jul 12, 2025 | 01:56 PM
Pantomime's Avatar
2016 E350 Sport
My factory installed mounts failed after 40K miles, so let’s see how long these Febi last for. It’s known how mounts on the W212 are one of its Achilles tendon.
Old Jul 13, 2025 | 10:31 PM
S-Prihadi's Avatar
Engine mount is a comfort consumable component.
It is not about how long it will last, it is about how well zero vibration transfer to your car should handled by the said mount.
I replace mine every 25,000KM
I am now at 43,000KM ish and on my third set of engine + tranny mounts, including 1st one from factory built in 2014. Thus I replaced on my own twice already.
My roads are bad too.
