Sponsored by: CARiD
2012 Mercedes E350 (M276) – Overheating, No Engine Code
Old Jul 18, 2025 | 01:35 PM
KlameBenz's Avatar
e350 4matic
Hey MBWorld Family,
I am new in the forums and I have been searching, reading everything about my overheating problem but couldn't find a related problem.
I’m dealing with an overheating issue on my 2012 Mercedes-Benz E350 4MATIC (V6, M276 engine) and could really use some insights. My car overheats when I start to drive a bit, but no warning on the dash, the temp gauge goes all the way to the top 120.
Here's the full breakdown of what's going on:
Engine temperature gauge rises to the top, but no official “overheat” warning on the dash.
Fan runs constantly, even after a short drive.
Heater blows only cold air, even with the climate set to max heat.
Car feels underpowered when drive since overheating / reduced throttle response, as if it's in limp mode.
Coolant is present in the reservoir and radiator. I confirmed that by opening the radiator cap when the engine was cold - coolant flowed out briefly. No coolant leak visible externally.
No check engine light related to coolant temperature sensor (CTS) - only one active code for an O2 sensor.
I’ve previously used (almost 1 year ago) BAR'S Leaks Liquid Copper Block Seal due to a slow coolant leak, unsure if that’s now causing blockage.
Also, since there's no warning light or check engine code related to overheating, it's really hard to pinpoint the exact cause.
There’s no visible coolant leak either. My mechanic suggested replacing the coolant temperature sensor (CTS), but before spending time and money on that, I’d really like to narrow it down and confirm the root cause.
Any advice on what I should check next would be really appreciated.
Old Jul 18, 2025 | 01:45 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
COOLING MAINTENANCE TIME
Originally Posted by omer.zdm
Hey MBWorld Family,
what's the current mileage and service history?
Is this truly overheating or showing false temp??
(**) half the engine is overheating!
-- You don't have a missing coolant issue. Level is stable.
-- CTS is reliable sensor: unlikely bad itself.
ECU circuit may be unstable but not sensor itself.
That leaves us with Tstat but they normally fail open... HOWEVER you've used "leak sealant" that is likely hurting. I would replace tstat as maintenance step.
I dont think pump plastic impeller got jacketed with stop-leak.
Your top suspect are: plugged up HEATER CORE + Radiator & Oil exchanger.
M276 cooling is made extra-slow by mapped-Tstat.
** : BANK2 IS OVERHEATING: "half the engine"
Bk2 is where the single temp sensor is located.
Bk2 heat is very well measured.
Old Jul 18, 2025 | 01:48 PM
KlameBenz's Avatar
e350 4matic
Thank you for your reply!
current mileage is 129000
Old Jul 18, 2025 | 01:57 PM
chassis's Avatar
2017 GLE350 4MATIC
Does W212 have a desiccant bag issue like W204?
Old Jul 18, 2025 | 02:10 PM
COOLANT REPAIR TIME
130kMi: time for summer maintenance.
The tiny hose between radiator and expansion tank has a check-valve built-in. Get a new assembly.
Up for debate is the engine Bk-2 rear coolant pipes. Firewall elbow is No2 leaker.
Replace now + flush or replace heater core circuit.
> BANK2 VS HEATER PATH
@S-Prihadi Surya, do you recall if 100% of bank2 coolant must circulate out through the heater-core right?
Meaning when heater-core is plugged up Bk2 gets limited/zero circulation, right?
Need a new heater or a bypass surgery.
Old Jul 18, 2025 | 02:17 PM
This could be?
No problem is too small to be overlooked.
M276 coolant circulation is kept slow to "save-gas"
Old Jul 18, 2025 | 02:36 PM
COOLING REPAIR LIST...
So all the above translates into...
MAIN PARTS:
  • Heater core
  • Engine Radiator
  • Oil Heat-exchanger
MISC COLLATERALS:
  • Thermostat
  • Hose to exp. tank
  • Genuine MB Coolant sensor
  • Elbow pipe to firewall
  • Bank2 coolant sensor + pipe
  • Misc new O-Rings seals
  • 2Gal. pre-mixed BLUE ZEREX coolant
Primary engine heat accumulation is caused by limited oiling of dry pistons.
Old Jul 18, 2025 | 02:57 PM
KlameBenz's Avatar
e350 4matic
Thank you all for your replies!
MAIN PARTS:
  • Heater core
  • Engine Radiator
MISC COLLATERALS:
  • Thermostat
  • Hose to exp. tank
Thank you so much for everything you’ve shared
I really appreciate the detailed explanations.
As a Mercedes fan, the health of my car is very important to me, and based on your recommendations, I’ll move forward with the following:
  • Replace the small hose between the radiator and the expansion tank (including the built-in check valve)
  • Replace the firewall elbow pipe (the #2 leak source)
  • Flush or replace the heater core circuit
  • Possibly replace the rear Bank 2 coolant pipes
  • Install a new heater core or consider a bypass solution if necessary
Also, when the overheating first happened, I checked the oil level and it was low. I added some oil afterward.
Do you think this could be related in any way to the overheating?
please correct me if I am missing anything
Thanks again for all your help
Old Jul 18, 2025 | 05:03 PM
TAMING HIGH HEAT
please correct me if I am missing anything.
I like your focused approach on repairing only Bank2 at first. You understand what's involved.
Your engine has endured true overheat temps, not crazy sensor.
Now consider disabling the "Mayo-Mixer"...
the radiator mixes with tranny ATF
the Heat-exchanger mixes with engine oil
(the front timing-cover)
The coolant cap 21Psi is not really good at preventing overpressure to trigger the mixer.
Keep an eye on oil for mayo evidence or better yet: prevent high-heat...
Low engine oil is from it getting vaporized back in the intake plenum and onto valves. You could experiment with better oiling to help circulate pistons heat out.
Old Jul 18, 2025 | 09:58 PM
S-Prihadi's Avatar
Yes, heater core always get bank 2 coolant output.
M276 has no stop valve of any kind.
Old Jul 18, 2025 | 11:30 PM
OUTPUT IS HTR-CORE
so you either need a clean/new heater core or a bypass surgery to get Bk2 coolant to flow out.
The heater core replacement job with dashboard out may not be cost-effective.... a little coolant bypass will help Bk2 cool better than new for peanuts.
Old Jul 19, 2025 | 03:14 AM
S-Prihadi's Avatar
Hey MBWorld Family,
In red is very likely the cause.
Stop leak is a last resort when you want to sell the car and hide the leaking issue or you want to keep the car for only a bit more time and get rid of it.
If you want long term keeping.....hhhmmm, removing stop leak will be a nightmare.
Old Jul 19, 2025 | 11:19 AM
KlameBenz's Avatar
e350 4matic
you are definitely right,
that’s why before I start doing any repair, I will begin by doing a coolant flush/cleaning and go from there.
any other advice about what I can do more?
Appreciate for response
Old Jul 19, 2025 | 11:43 AM
KlameBenz's Avatar
e350 4matic
Yep, that was definitly helpful, I really Aprecciate it.
I will start doing the steps in next week and update it from here.
Thank you to all of you for your recommendations and information.
Couldn’t think these forms could be helpful that much!
Thank you !
Old Jul 20, 2025 | 10:28 AM
S-Prihadi's Avatar
I do not know how to get rid of hardened leak sealer.
Supposedly it will harden when exposed to air, a leaking cooling system is basically open to "air".
Our cooling system is pressurized and the only air is at the coolant bottle ( Black/white ), 1/2 of it is air on purpose black portion fo expansion, black+white portion meet up is maximum level.
Maybe google and use Utube to find how to remove leak sealer for radiator.
Old Jul 20, 2025 | 10:36 AM
KlameBenz's Avatar
e350 4matic
okay, thank you for your advice, the thing I know is the coolant is not reaching to radiator currently, because coolant is full and car give me low coolant warning
Old Jul 21, 2025 | 07:12 AM
S-Prihadi's Avatar
Coolant actuall full but warning is LOW, meant either the coolant sensor probe is not working or some connector/wire get disturbed.
The sensor is at the black/white coolant expansion bottle. Its a 2 prong metal sensor.
Old Jul 21, 2025 | 09:18 AM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
The warning message with the orange thermometer sometimes means coolant low, but not always.
Our '14 E350 (M276) started displaying this error intermittently. The coolant level was fine, but the error message would be displayed and then disappear, as the car was driven.
Short story: took the car to a reputable independent who diagnosed a bad thermostat and intermittent cooling fan errors. After replacement of the thermostat & fan all errors were resolved.
So it's not only low coolant which can cause the orange thermometer icon to be displayed.
Old Jul 21, 2025 | 07:22 PM
KlameBenz's Avatar
e350 4matic
Coolant Flush
Update:I opened the radiator drain plug from underneath to drain the coolant, but only a small amount came out. The coolant reservoir didn’t change at all it didn’t go down even a little.
I am assuming the pipes are clogged?
Old Jul 21, 2025 | 08:15 PM
S-Prihadi's Avatar
Were you able to pull out the entire drain valve ? Black plastic thingy, below :
Also open the black/white coolant reservoir cap ( as vent ) when draining coolant from radiator bottom drain valve...
Old Jul 21, 2025 | 08:35 PM
dmatre's Avatar
As noted above, if you didn’t open the reservoir cap, then the system will draw a vacuum with the drain plug out, allowing just a small amount to drain before it stops.
Old Jul 21, 2025 | 08:40 PM
KlameBenz's Avatar
e350 4matic
no I couldn’t, I only opened but didn’t pulled out.
Old Jul 21, 2025 | 09:34 PM
dmatre's Avatar
Old Jul 22, 2025 | 11:04 AM
KlameBenz's Avatar
e350 4matic
Important Update
Thank you for everyone for your recommendations and helps.
As mentioned, I was trying to remove the hoses to see if there is any clogged because of the leak sealer I used in the past, and good and bad news is I found it....
The hose and the radiator was completely clogged because of the coolant sealer. And that was a good lesson for me never use to this kind of product.
At the end, I removed the hose and cleaned it completely, but unfortunatly the raditor is also clogged and I will get a new radiator instead of cleaning as a best option for my car health.
Thank you and never use leak seal product for your car.
Old Jul 22, 2025 | 11:44 AM
S-Prihadi's Avatar
Wait wait wait.......your oil cooler will be clogged too and most likely the HVAC heater core.
If you have boroscope, it will do you much good to inspect suspected clogging where camera can go in.
DAMN, that thing can clog that bad ???????
