722.9 transmission: Valve body or conductor plate issue?
The 2-3 issue completely disappeared when I reset adaptation values myself, but no improvement to the 5-4. It downshifts from 5 to 4 smoothly under deceleration and even under light acceleration, but the kickdown delivers a startling kick in the pants under medium to heavy acceleration, unlike any other gear. Definitely not how it left the factory.
No codes are thrown at all by the transmission module.
From what I've read, these problems tend to be either a faulty speed sensor on the conductor plate, or a component (solenoid, clutch, brake?) in the valve body. I'm handy but I don't really understand transmissions at that level.
Anyone with more experience have a suggestion for most likely cause, further testing I should do, or anything else helpful? I don't want to attempt to replace/repair something that isn't faulty.
You have ok ATF already...
Double check how many non-TCU chassis faults are reported.
Poor engine throttle control are likely causing you delayed bangy shifts. Nothing else too fancy.
I believe that your transmission mount is vulcanized rubber.
Replaced mine and it's such a noticeable smoother gear shift sequence.
This is a combination of issues from
the ECU working the throttle body
plus the busy CAN-Bus:C.
> HOW IS THAT ...
-1- the ECU does not have perfect throttle control for at least two reasons: the air intake camshaft is made unstable by low oil pump pressure and the chassis variable voltage (12.6 to 14.9) is not well tolerated by TB coils (regardless of pulsed width).
That boils down to stock TB response can be improved.
-2- The CAN-C is shared between ESP- ECU-TCU-ISM-FSPU... is swamped to max bandwidth, it delivers delayed data. This prevents timely cooperation and disables matched rpm using engine throttle.
The long story short is the platform needs effective stability:
- stable OIL pressure to position VVT
- stable VOLTAGE to drive all electric coils
- stable CAN-Buses from CGW
- stable sealed compressions
- stable HEAT levels (coolant/oil/ATF)
- equal predictable powertrain maps.
> You can begin experimenting with a really simple REBOOT + Float: effective for a while (from 1 day, to 1 week).
Every stock condition you improve comes closer to nimble "pressure sensitive" throttle with seemless shifts. Focus on the engine, the great tranny will match.
> HOW IS THAT ...
Can you please elaborate on what you mean by Reboot + Float. Thank you. Are you referring that there might be an underlying engine issue that is causing this transmission symptom ?
Thank you for the explanation.
-- SPEED: High gears selected at low speed such as 6th gear at 35mph!
-- HOW: Sloppy-slipery shifts instead of matched RPM's
-- WHEN: Delayed banging-shifts instead of coordinated shifts
Should you recognize these conditions, you can have a look here to experiment turning this around simply.
Once the engine gets predictable, tranny begins to match it perfectly with its self-adaptations.
Great seemless shifts are instantaneous & fast with matched shaft RPM in the gear that delivers normally driveable output torque: 1,2 or 3 not 5 or 6.
