Sponsored by: CARiD
“Don’t Forget Your Key” Message
Old Sep 20, 2025 | 06:51 PM
Pantomime's Avatar
2016 E350 Sport
How do I deactivate this silly message that greets you opening door? There’s probably a path on Launch scanner, if someone knows how to do it. If you forget key inside car, it won’t lock, so not sure what the purpose of it is.
Old Sep 20, 2025 | 08:19 PM
DFWdude's Avatar
2016 E350 Sport
Ya know... some things you just learn to ignore...
Old Sep 20, 2025 | 09:08 PM
TimC300's Avatar
With a Launch scanner, not sure.
Can try the advise in this thread: https://mbworld.org/forums/sl-class-...my-pocket.html
Old Sep 20, 2025 | 09:11 PM
W205C43PFL's Avatar
A very North American MB feature, this is not a message present in European MBs for example.
Old Sep 20, 2025 | 11:02 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
I have gotten this message before.
I put a new battery in the fob, and the message has not reappeared.
I don’t know for sure, but I suspect a weak fob battery.
Old Sep 20, 2025 | 11:28 PM
Pantomime's Avatar
2016 E350 Sport
I don't think so, this is a standard feature on so many MB vehicles. I wish it was that simple.
Old Sep 21, 2025 | 03:11 AM
S-Prihadi's Avatar
So USA cars also comes with door open boing-boing warning ?
I dont use push button, I hate it. I love manual insertion of the keys and turn CC1 and CC2 and CRANK, where it is the best and safest set up when you often play with scanner/xentry like I do,
more so when doing relative compression test to drive up engine oil after engine dormant say 3 weeks.
My key fob battery can last 2+ years as there is a coil at its end which get power supplied to the key fob from N73 key slot in contrast to push button where
the key fob need to work all the time on its own battery power.
Old Sep 21, 2025 | 03:59 AM
BenzV12's Avatar
W212 FL
I don't remember if I have ever seen the same message before . Coding should make it go away
Old Sep 21, 2025 | 03:17 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
The OP's message has been ever present on both my '13 E350 and my '13 ML350 bluetec. It wasn't there on my '05 E320CDI but then I didn't have keyless go either.
What WAS present on the E320 - that I miss a little bit - was the message telling me that the sunroof was open (whenever I left it open). These cars really don't do well with water in the passenger compartment.
Old Sep 21, 2025 | 07:44 PM
W205C43PFL's Avatar
Hmmm strange they removed that message then on.
In Europe, european spec MBs can automatically close the sunroof when the rain sensor detects rain. Due to regulations, we don't have that luxury in North America.
Old Sep 22, 2025 | 03:28 AM
BenzV12's Avatar
W212 FL
I know that , the sunroof automatically closes by itself anyway I mean you would not leave it open all day long . It must have been like 6 hours or so if I remember correctly . I hate those stupid things but I don't wanna get banned as I stop here
Old Sep 22, 2025 | 08:16 AM
Arrie's Avatar
If your key fob battery dies the car will lock with key inside.
Old Sep 22, 2025 | 08:44 AM
Arrie's Avatar
Wonder if the car will lock with sunroof open? It will not if the hood is not closed. It will if windows are open though…
Old Sep 22, 2025 | 09:44 AM
W205C43PFL's Avatar
Edit: please see the answer by another forum member followed.
Old Sep 22, 2025 | 10:15 AM
JettaRed's Avatar
Veteran: Army
It definitely will with the sunroof tilted open, which is what I do on hot days to let the heat out. My SL also locks with the top down, which sets the alarm.
Old Sep 22, 2025 | 10:31 AM
W205C43PFL's Avatar
Could be coded out, no?
Old Sep 23, 2025 | 12:31 AM
BenzV12's Avatar
W212 FL
Many things can be coded to get the things working you know even later models' key fobs
Old Sep 23, 2025 | 01:56 AM
W205C43PFL's Avatar
Certianly. I mean, you can also do anything you want if only we have the source code...
