Sponsored by: CARiD
Repair Cracked Climate Control Glass
Old Nov 11, 2025 | 01:25 PM
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
Has anyone repaired the common cracked clear plastic on the climate control? It doesn't look like the plastic is easily removed.
Old Nov 11, 2025 | 05:04 PM
TimC300's Avatar
Replace it with what, are you finding just the plastic part sold separately?
Is it cracked, or is there a protective film that is wrinkled? I dont have that climate control so not sure what it looks like in person.
Seems if it is cracked then a used control unit would be the cheapest option.
https://mbworld.org/forums/e-class-w...tic-cover.html
Old Nov 11, 2025 | 05:16 PM
Sambugnet's Avatar
W212
Same problem here...
Old Nov 11, 2025 | 05:37 PM
Davery's Avatar
There is no protective film on the unit. I actually did replace the entire unit with a used one off ebay. There are many part numbers for this and while the used unit works, it does not work correctly. I have a convertible and with the top up, they auto will not provide AC until I select Max AC for a few minutes and then switch back to auto. I suspect either the part number for the climate control is a different number for the convertible or the unit needs to be flashed or coded to work correctly on my car. Anyway, just seeing if it possible to repair my original unit and reinstall.
Old Nov 16, 2025 | 02:41 PM
sqeedy@wp.pl's Avatar
Mercedes A207 E350
Hey, I had the same problem. I bought the first panel I saw with the glass intact and replaced it. It's not easy, especially removing the front buttons—the clips can break. I first disassembled the new one and only then tackled the original one to check and know what to pay attention to.
Old Nov 16, 2025 | 03:41 PM
Davery's Avatar
I can't figure out how to get the broken glass off. You took the buttons off? Do you need to do that to get the glass off?
Old Nov 16, 2025 | 05:49 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Front does not come off. Its a unit.
Old Nov 16, 2025 | 07:44 PM
TimC300's Avatar
Looks like there are some philips head screws holding the front and back plastic cases together. probably unscrew them and the case splits apart. The electronics are probably just floating in there easily removed. Can probably remove and swap out the buttons at this time. Looks like the glass part is attached/glued to the front part.
Can probably swap out the entire front with any other unit as long as it has the same number of buttons. I see some have 7 buttons and some have 8. Im guessing there are led lights at the top of each button.
Old Nov 16, 2025 | 11:56 PM
Mercedes A207 E350
mate, if I find the old panel today, I'll try to send photos, it's not an easy procedure but it can be done.
Old Nov 17, 2025 | 07:28 AM
Davery's Avatar
I messed with the broken unit last night and there are five 5T Torx screws to remove the back. The circuit board just lifts out. Since I have the same number of buttons and the buttons are in great shape on the ebay unit I installed a few months ago, I am just just going to swap the circuit boards. It will probably be a couple of weeks before I have time. The hardest part of the job is removing the center AC grills. I can never find those tabs inside the grills. I have been using a couple thin rods I have bent to work (poorly). Anyone else have a better idea to get to those tabs inside the grills? Thanks for all the insight.
Old Nov 17, 2025 | 09:20 AM
Mercedes A207 E350
So if you want me to send you photos, let me know.
Old Nov 17, 2025 | 09:34 AM
Mercedes A207 E350
Kolega, jak dziś znajdę ten stary panel, to postaram się wysłać zdjęcia, nie jest to łatwa procedura, ale da się zrobić.
After unscrewing, gently drill out the welds. Pull out the buttons on the front of the panels. Note: Be careful, as you may damage the latches. You can then remove the glass. The welds are marked in red.
Old Nov 18, 2025 | 02:21 PM
TimC300's Avatar
From the instructions in the manual it looks like there is a small panel/trim piece under the radio that comes off to reveal two screws for the top of the ac unit. Is this what you are removing?
Old Nov 18, 2025 | 03:24 PM
Meh, for my time? I will just buy a new one (and need to).
Old Nov 19, 2025 | 02:05 AM
BenzV12's Avatar
W212 FL
Sorry no help from my side but I didn't know those were fragile at all
Old Nov 19, 2025 | 11:13 AM
benidB's Avatar
W212
common? i have never seen one crack before
Old Nov 19, 2025 | 12:17 PM
I have had that EXACT same unit in four cars now...currently in my 63 it is cracked...as I had to slam on my brakes to not hit an ignorant terrorist with a badge (local cop) and some lumber slid forward and hit it...so, thrust a 2x4 into....quite brittle
