Sponsored by: CARiD
Recall Airbag - they killed the car
Old Dec 1, 2025 | 01:05 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
So, Gainesville FL MB was going nuts they needed to warranty replace the airbags in one of my cars. I politely told them that I was not driving (an hour) to get the thing. They sent a very nice guy to my home to replace the airbag....
Well, went to actually use that car this AM....
Old Dec 1, 2025 | 04:06 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
DEAD FLAT BATTERIES
they really delivered.... Something on CAN-B must have stayed ON to drain both batteries.
Do not jump but charge up then scan chassis for list of all faults.
Old Dec 2, 2025 | 12:52 AM
S-Prihadi's Avatar
Techy forgot to re-connect the ground post on the battery
No sane person would remove steering airbag without disconnecting battery ground.
I removed mine like 10 times already...for various reasons and I am always AFRAID when it comes to airbag
Old Dec 2, 2025 | 01:54 AM
BenzV12's Avatar
W212 FL
How on earth this could happen poorly botched by a qualified technician
Old Dec 2, 2025 | 11:31 AM
recall... no crank!
That's the recipe of a free service followed by a paid service.
Lets see how this gets handled :
-A- "sorry we messed up" ?
-B- fees + parts + labor ?
Somebody is gonna have to figure out this issue...
Old Dec 2, 2025 | 12:33 PM
This AM I was told "clearly the car had other things going on"...and the Service Manager is out for the day...the store General Manager does not get involved with "service issues such as these"....
Then, these idiots wonder why my cars NEVER go to Gainesville for service? If I do need dealer service I go to Orlando.
Funny, I just remembered when I had a key programmed for this car the proximity sensor and "touch lock" on the handles did not work. Gainesville MB said that my car did not have that option.....it was a like three day fight before it was finally fixed. My other key proved it worked.
Old Dec 2, 2025 | 03:29 PM
Lexuslover's Avatar
2023 s580
I don’t get it ???
so your telling me that the mechanic didn’t even turn the car on after the airbag installation to see if everything is working properly.?
I mean, some people are lazy so I can understand not to do a test drive, but not even turning on the car to see if there’s no lights on. It’s kind of ridiculous.
That’s why I do all my oil changes and Maintenance at independent mechanic shops. It’s more personal Because you’re actually talking to the mechanic working on your car and explain in details what’s the issue? in a dealership your just a vin number.
to me personally a dealership is just to buy the car after that goodbye even with all the free Courtesy oil, changes and stuff never went back always independent.!!!
The dealership That performed this recalled probably say your car was like this before we started on it..!!!!
good luck..!!!!
That’s why it’s good to have cameras everywhere because cameras don’t lie people do.!!
Old Dec 2, 2025 | 03:41 PM
survey lips service
MB USA uses a dealership survey system graded from 0 to 10 points to track their network of professionals.
Be sure to inquire about this survey feedback - It won't change anything: MB service is already "the best or nothing!"
Old Dec 2, 2025 | 06:12 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Those airbags are scary, even when you aren’t removing and installing.
The boys from Jackass and other daredevils used to play airbag roulette, and when they went off, it looked like their fall would cause all kinds of serious injuries, after being launched into the air a few feet.
Old Dec 2, 2025 | 08:45 PM
All blocked
Old Dec 8, 2025 | 07:03 AM
Dave Backmarker's Avatar
2018 AMG GT S, 2016 E350, 2013 GLK350
I suggest your fear of airbags to be very wise. I was working with a manufacturer who was testing airbag designs and two technicians were decapitated while testing prototypes. A reminder to everyone: After the battery has been disconnected, let the airbag’s capacitors drain. I wait twenty minutes which is much more than required but I’m still here to talk about it.
Old Dec 8, 2025 | 07:51 AM
I still have not figured that car out. I put in a brand new battery....over night the new battery was down to 9.1v. Now, the car does not start again. The ONLY thing that changed was that airbag.
Maybe I am lazy but that car is just not high on my priority list.
Old Dec 8, 2025 | 02:03 PM
1000 cuts / AAC?
Unfortunately your car has developed a case of hungry Gremlins.
Translate that as...:
some of the electronics stays awake abnormally long during security calls.
some of the unprotected electronics got wet
some of the modules are causing the gateway to get unstable.
Run a full chassis scan report for a list of unstable/faulty modules.
######## Your luck now !!??
I recall you had issue with the AAC Module getting smashed by a piece of lumber inside the car, right?
This is a perfect candidate on CAN-B with always on power supply. Disconnect or replace this (solderless) AAC.
