Sponsored by: CARiD
Trunk water leak!
Old Dec 25, 2025 | 01:22 PM
nguyenphananh's Avatar
slk280
Trunk water leak!
Hi, I need helping ideas with leaking water in the trunk. I discovered in my newly acquired 2016 E350, after a short car wash, or quick rain, there was water leak in the trunk floor, the area around spare tire, aux battery and fuses box!. Interestingly, the trunk's carpet is totally dried, indicated the water leaked straight down to the trunk floor, not through the carpet. I already visual inspected the seals, general areas.... and everything seem normal. Anybody has any ideal where the leak might have come from? where to check?. My family member bought this car brand new. After few years, there was a recall for trunk leak, so dealer installed a "seal" directly at the bottom of the window! (never seen anything like that before). Now since Im taking over the car, I started to pay attention... and despite the "fix", water still passed into the trunk, even with a short car wash!.
I also have a 2008 W211, which suffered a notorious trunk leak. There are many discussions about this issue on the forum. I already replaced the tail lights gasket seal, siliconed all the holes, opening on the trunk lid, yet it still leaked!. However, when it leaked, the trunk carpet was all wet. Im so frustrate Mercedes couldnt design a car without leaking trunk generation after generation. Even the cheapest chinese cars dont have this problem....
Old Dec 25, 2025 | 05:39 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
WET XMAS DEAL
These excellent cars feature a collection of engineering issues refined year after year
The sunroof discharge has 4 plastic pipes that shrink and pull-off...
Discharge hoses use a rubber nozzle that conveniently glues itself shut to overflow...
The water discharge channel area surrounding the trunk lead seal features a plastic cover fastened by rubber pins that are drilled straight into trunk area...
You describe an entry point that seems low-down not up-high...
Remove the side carpeting for inspection.
Use paper towel as markers of rain entry...
Old Dec 25, 2025 | 06:14 PM
TimC300's Avatar
My W204 was leaking from the trim fasteners. Verified by inspecting the underside in the trunk right after a rain storm.
If i were looking for the source of a leak i would pour water starting at the lowest point, inspect, then if dry move up to the next spot. Thats how I used to test windows for leaks, use a garden hose and direct the water along the sills for a few minutes then looking inside for signs of water, if nothing them move up the jambs, then head.
testing sliding sunroof drains is easy and just pour a cup of water and see if it drains or gets backed up. Then look for water dripping out the bottom onto the ground.
There are also some vents (50) on the sides of the trunk area. Could always check the area around the vents inside for water. I dont see this being the cause but worth a look.
Old Dec 25, 2025 | 06:52 PM
. (dup post).
Old Dec 25, 2025 | 06:56 PM
ENGINEERED... WATER-WORKS
trunk water pooling area
This looks like a TPMS Module, W204 right?
On the W212 facelift it is installed outside the trunk in the wet location over axle
Leaking rubber pins...
water entry point
water entry point
> SOAKING OPPORTUNITIES: Shower vs. Tub ?
This is the rear end with R-SAM exposed to shower when rubber seal expires...
The front end has similar set of opportunities to fill up the F-SAM tub enclosure using water from:
  1. windshield polyurethane glue
  2. roof seems loose
  3. sunroof drain pipes
  4. cowl drains obstructed
Rain is guided right inside the SAM tub enclosure channeled by harness bundle. Electronic board is built without any conformal coating.
Lexus is using "NEARLY waterproof" harness connectors like W212.DO SILICON RTV every single connector you see outside cabin area:
-A- Rear bumper area (radars, TPMS!)
-B- Front bumper area (A/C pressure Sw! + side harness!)
-C- Engine bay area sensors
The connector waterproofing task has low-priority It's a simple step towards basic reliability.
Compromised connectors a serious PITA to repair once oxidized - Contact tiny springiness is compromised regardless of being cleaned and sealed.
CarCareNut uses the word JUNK to name this 2023 Lexus connector downgraded to guarantee issue.
Old Dec 25, 2025 | 09:12 PM
slk280
Thanks for the ideas. I was hoping for a quick solution. Looks like I will have to do water test to identify the leaking point. On the W211, I already replaced the plastic water channels on the L and R side of the trunk; replaced all the rubber pins, plastic clips. I even silicon these whole area, replace tail light gasket, yet it still leaked!. I did what ever I could thought of, proofing the whole trunk, yet it still leaked!. On the W211 forums, it was a recurring issue, and there was no absolute fix for it....
Old Dec 25, 2025 | 09:22 PM
You should apply all your W211 expertise to fixing this W212 in hope it's using a shared design issues you know.
I guess the rear windshield seam should also be tested here
Old Dec 25, 2025 | 10:30 PM
slk280
will look into it. It been raining hard here in the past days
Old Dec 26, 2025 | 12:00 AM
heavy downpour...
is like mother-nature extending a helpful hand for your testing.
