Bulletins 213
Received 4,446 Likes
'71 Pinto
Bulletins 213
LI91.16-P-063434 FEB16 – 213 VIN A000865 to A002740 rear head restraints move up sluggishly, clean bars and apply lubricant 00098935660.
LI82.35-P-063732 APR16 – 213, 253 windshield washer spray nozzle on engine hood loose, apply adhesive pad onto long catch tab (see image).
LI09.10-P-063980 MAY16 – 213 w/274 engine up to 4/1/16 production date cracking noise from engine compartment during throttle lift-off, remove side catch tab to air intake duct upstream of filter.
LI82.85-P-064051 MAY16 – 213 w/code 464 central display malfunctions sporadically COMAND audio remains functional, repair cable set and line bracket.
LI54.25-P-064053 MAY16 – 213 up to VIN A025655 switch block on lower control panel is loose or not correctly engaged, remount making sure all catch hooks are engaged (see image).
LI72.00-P-064122 MAY16 – 213 front/rear door wind noise at rear window corner, molded corner on inner dust shield seal may be too far forward shift to correct position (see image).
The following 8 users liked this post by konigstiger:
Diesel Benz (01-26-2017),
DMRDSM (07-19-2016),
Flash Gordon (04-04-2017),
iammrsam (05-05-2017),
unr1 (03-06-2017),
and 3 others liked this post.
my 2010 C300 was in ten times to find a rattling, noisy dash.
they finally removed dash and fixed. And generated bulletin.
when I drove the demo, the "hood" over the screens was making the same noise. I hope my new e class doesn't have to through the same process
'71 Pinto
LI82.30-P-064282 JUN16 – 213 windshield wiper stops without obvious cause < 6mph, update software and perform SCN coding.
'71 Pinto
Service Campaign 2016070001 JUL16 – coding to overhead control module (OCM) for garage door opener (GDO) may lose programming, dealer will update software. Approximately 4,498 vehicles affected. Have dealer check VMI to see if VIN is included.
LI68.05-P-064396 JUN16 – garage door opener (GDO) loses programming after vehicle ignition off and bus-asleep, perform initial startup on GDO control unit.
LI91.60-P-064402 JUL16 – message “PRE-SAFE Impulse Side Inoperative”, replace gas generator in relevant rear seat backrest. Airbag is designed for multiple deployments, up to 10.
LI77.21-P-064406 JUL16 – Panoramic roof with glass panel open whistling noise between 40 & 80 mph, attach adhesive strips to headliner clips.
unr1 (03-06-2017)
'71 Pinto
LI72.10-P-064593 JUL16 - 213 up to VIN A019195, L000125, Z003412 at speeds in excess of 120mph howling noise at front door left/right A-pillar area. Forward lip of window guide rail may separate at high speeds, replace window guide rail. DIY test, mask off guide rail as shown in picture below.
LI82.10-P-064641 AUG16 - 213 sporadic fault message that low beam at left/right inoperable however, function is fine with stored fault code B178392 update headlamp control unit software.
LI54.21-P-064645 AUG16 – 213 KG engine does not start, key not recognized. Check to see if there any traces of water on KG control unit located behind right rear trunk panel (see image below) if so, create a PTSS (MB assistance) case.
LI82.30-P-064587 AUG16 – 213 wiper blades scraping or squeaking, under analysis. Replace wiper and adjust wiper blades, create PTSS case. Advise customer to not use any sort of wax cycle in an automatic car wash, and to not use any sort of water beading product on the windshield.
LI54.18-P-064682 AUG16 – 213 moisture ingress into interior, firewall grommet may not be within specified dimensions. Install grommet using adhesive sealant. Assembly line clean point (resolve) expected 8/30/16.
LI49.20-P-064701 AUG16 – 213, 205, 253 Engine diagnosis warning lamp active, fault codes present for NOx sensor. Increased resistance at connection of NOx sensor due to potential moisture, check if center console carpeting or felt is damp. Replace condensation drain hose and, if necessary, parts/harness/ NOx sensor etc.
LI88.50-P-064728 AUG16 – 213 with electric trunk closer (881) trunk lid difficult to close, latch assembly alignment open PTSS case for replacement part guidance.
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
Any TSB's for a defective crankshaft? My car is being held in Germany waiting on the rework. I'm about to cancel the order on the vehicle as I'm not interesting in having a rebuilt engine in a new car that I've never even driven. Any idea how many VIN numbers are affected?
'71 Pinto
LI82.70-P-064726 AUG16 – 213 Difficult for the called party to understand or interference/background noises audible during phone call. Possible causes, assembly of microphones and/or wiring between microphone and head unit.
LI82.85-P-064727 AUG16 – 213 NTG5.5 vehicle positioning inaccurate (may drift away from road although vehicle is still on the road) and/or route guidance not possible. Faulty GPS antenna as indicated by fault codes + update COMAND control unit software if needed.
LI82.85-P-064888 SEPT16 – 213 (w/code 531) “Activating navigation. Please wait…” intermittently displayed. Update COMAND control unit software.
LI82.85-P_064897 SEPT16 – 213 (w/code 531) Route guidance not active display and instrument cluster always show direction as North, even when vehicle is moving in a different direction. Update COMAND control unit.
LI49.10-P-064640 SEPT16 – 213 M274 engine (e300) check engine light DTC P003613 output for the heater of oxygen sensor 2 cylinder bank 1 has an electrical fault or open circuit. Under investigation, open MB PTSS case.
The following 2 users liked this post by konigstiger:
unr1 (03-06-2017)
'71 Pinto
LI82.85-P-064937 SEPT16 – 213 station list intermittently shows only a few radio stations or none at all and still possible to select any frequency by entering manually, update COMAND control unit.
Service Campaign 2016100001 OCT16 - 2017 213 under certain loading conditions the rear seat bench seat frame could damage the wiring harness to the fuel system control module depending on the affected wire, it could affect the operation of the fuel pump, the fuel tank pressure sensor, or the fuel gauge. Should the fuel pump fail, the fuel supply to the engine would stop and the engine could subsequently stall. Dealer will repair/reroute harness. Approximately 6,858 vehicles are involved.
LI46.35-P-065046 OCT16 – 213 except 4matic “Steering Malfunction See Owner’s Manual”, water entry into steering gear through damaged boot or possible software error. Check steering gear, perform software update.
unr1 (03-06-2017)
'71 Pinto
LI91.16-P-065170 NOV16 – 213 with (code 275 memory) up to VIN A131673 passenger seat fault message or seat adjustment and/or head restraint inoperative, replace head restraint harness.
unr1 (03-06-2017)
'71 Pinto
Service Campaign 2016110004 DEC16 – 2016 & 2017 213, 253, 205 Audio/COMAND control panel was not calibrated properly, system cannot be operated temporary. Dealer will recalibrate. Approximately 15,251 vehicles affected.
unr1 (03-06-2017)
Are these recalls addressed in future production or does a new car arrive with recalls ?
'71 Pinto
unr1 (03-06-2017)
anything ?
'71 Pinto
In theory all vehicles delivered after bulletin, recall, and/or service campaign release date should be fine. But as we all found over the years with MB this is not always the case. If you have a particular concern and it is addressed in this thread, simply reference bulletin to SA.
dukester34 (12-29-2016),
unr1 (03-06-2017)
'71 Pinto
Service Campaign 2016110007 JAN17 – 2017 213 curve illumination & cornering lights inactive, dealer will activate function in headlamp control module. Approximately 3,866 vehicles affected.
unr1 (03-06-2017)
Thank you.
'71 Pinto
Need to have dealer run VMI for your VIN to determine if the vehicle is involved in campaign.
unr1 (03-06-2017)
'71 Pinto
Recall campaign 2017020018 MAR17 – 2016 & 2017 213, column mounted shift lever may become inoperative due to possible damage to internal circuit board manual drive mode selection (D,R,N,P) would no longer be possible. Auto P function & auto parking brake would still function. Should the condition occur at standstill, vehicle might not move as selected by driver. Dealer will replace steering column control module. Approximately 73 vehicle affected.
Recall Campaign 2017030003 MAR17 – 2017 213, front passenger seat occupancy control module might be incorrectly installed which could kink pressure hose when seat is moved towards rearmost and lowest position resulting in deactivating passenger airbag. Dealer should create a PTSS case for MB technical assistance. Approximately 12,454 vehicles affected.
Service Campaign 2017010004 MAR17 – 2017 213, incorrect nut & washer may have been installed on stabilizer bar to the steering knuckle this may lead to noises while driving. Dealer will replace. Approximately 6 vehicles affected.
LI68.10-P-065805 FEB17 – 213 trim ring of adjustment wheel at air vent id off center or loose, center and fasten with additional bolts, see image below.
LI72.40-P-065822 FEB17 - 213 window reverses direction at upper end position, until remedy is available completely open/close window to undergo teach-in (press switch to first notch only).
LI82.85-P-065949 MAR17 – 117, 156, 166, 172, 176, 190, 205, 207, 213, 217, 218, 222, 231, 238, 242, 246, 253, 292 with code 360, 362, 364 (HERMES communication) SOS message “Service Not Activated” code B15CE00. (1) Perform recommissioning with XENTRY Diagnosis and then conduct a brief test drive. If this is not effective, please create a PTSS case (MB technical assistance). (2) Contact Verizon Telematics Dealer Support at 877-826-6319. If the complaint cannot be resolved by Verizon Telematics, create a PTSS case.
'71 Pinto
With the exception of 065822 you should be fine. For peace of mind request VMI (vehicle master inquiry) confirmation that there are no outstanding recalls or service campaigns. I should note this should automatically be done via PDI (pre-delivery inspection).
davekarn (03-27-2017)
