E-Class (W213) 2016 - 2023
Ceramic Paint Coating and Rustproofing
Old Jul 13, 2017 | 10:03 PM
torca2017's Avatar
2018 E400
Has anyone used Ceramic Pro or other ceramic coatings on the Eclass? Can you recommend someone in the Toronto Area?
My dealer was offering the electronic rust control module and I declined it as I have read that it does not work. He told me that Mercedes does not recommend rust sprays. This seems unlikely to me. What have you heard and have you used rust proofing sprays? Thanks!
Old Jul 14, 2017 | 12:46 AM
c4004matic's Avatar
17 E43; 21 GLS580
No manufacturer recommends rustproofing because its pure BS, in fact, it may promote corrosion if it blocks the water draining gutters. Moreover new vehicles are made with aluminum and plastic plus every exposed steel part is coated, ergo, many vehicles are virtually corrosion proof.
Ceramic coatings are also mostly snake oil basicly a longer lasting polymer based wax that contains ceramic microparticles which more than anything serve as an abrasive. Contrary to the BS it doesnt form a ceramic "shield" of any sort which would take a kiln to melt it.
Old Jul 14, 2017 | 12:49 AM
c4004matic's Avatar
17 E43; 21 GLS580
No car manifacturer is in the business of making rusty cars or short lived paint if there was some magic potion out there they would use it!
Old Jul 14, 2017 | 11:24 AM
petee1997's Avatar
...24 GLE53
Did we go to the same school?
Old Jul 14, 2017 | 11:42 AM
c4004matic's Avatar
17 E43; 21 GLS580
where did you go?
Old Jul 14, 2017 | 11:52 AM
petee1997's Avatar
...24 GLE53
where did you go?
I was just agreeing with your common sense on guns and rustproofing. Doubtful we attended the same university since I went to university in Canada.
Old Jul 14, 2017 | 04:01 PM
Jan AMG's Avatar
The best or nothing
I have applied ceramic coating to my CLS. So far so good, try it, you will be happy with the extended protection.
Old Jul 14, 2017 | 07:18 PM
dae123's Avatar
2017 E300
I have Opticoat Pro+ and happy with it- 7yr warranty and supposedly doesn't wear off (any more than a traditional clearcoat, that is).
Old Jul 14, 2017 | 08:34 PM
c4004matic's Avatar
17 E43; 21 GLS580
I was just agreeing with your common sense on guns and rustproofing. Doubtful we attended the university since I went to university in Canada.
And I PR!
Old Jul 14, 2017 | 09:12 PM
torca2017's Avatar
2018 E400
Thanks everyone.
Old Jul 21, 2017 | 10:43 AM
sam5002's Avatar
gle350d
What is the best rust protection ? Can someone please recommend.
I live in Toronto area.
Old Jul 21, 2017 | 10:45 PM
c4004matic's Avatar
17 E43; 21 GLS580
Simple, there is no need for additional rust protection. Again, modern vehicles replace most areas prone to rust with plastic, most exterior surfaces plus the suspesion are rust proof aluminium. Your E class' engine will probably be dead a long time before it rusts through.
Old Jul 22, 2017 | 08:12 AM
sam5002's Avatar
gle350d
Thanks for your reply C4004 matic. I have 2016 GLE 350d it applies to this vehicle as well i believe .
Old Jul 22, 2017 | 11:50 AM
c4004matic's Avatar
17 E43; 21 GLS580
Sure does! As cars endeavor to be lighter rust will be a thing of the past. One problem however that manufactures face is how to maintain the old fashion klunk of the door since they are much lighter and "tinnier."
Old Jul 22, 2017 | 12:27 PM
ua549's Avatar
Soft close doors. Klunk is neither expected nor required.
Old Jul 22, 2017 | 01:43 PM
c4004matic's Avatar
17 E43; 21 GLS580
True
Old Jul 25, 2017 | 02:11 PM
greasykid's Avatar
2015, ML250 BlueTEC
Rust proof sprays.
MB has not recommended this for the last 30-40 yrs.
Old Jul 25, 2017 | 02:14 PM
greasykid's Avatar
2015, ML250 BlueTEC
move
Old Jul 27, 2017 | 12:19 PM
c4004matic's Avatar
17 E43; 21 GLS580
BTW the design magno paint does have micro ceramic where it counts: IN the paint.
