E-Class (W213) 2016 - 2023
Latest version of command?
Old Nov 5, 2020 | 02:54 PM
  #176
JakeW213's Avatar
W213 220d from 2016
Originally Posted by KSubedi
You might be one of the first people to get that update. Do you have a pic of the dealer version menu so I could compare other software versions. Also what W213 do you have?
My car is a W213 220d from 20th of May 2016 and here is the dealer menu. Freshly updated yesterday
Old Nov 5, 2020 | 04:55 PM
  #177
BenzC400's Avatar
AMG CLE 53
Originally Posted by JakeW213
Just got my car back and version updated to is 05.80.00.00 so I guess this is the newest comand update posted. Cheers for the assistance
Have you noticed any differences or changes in appearance or function with the update?
Old Nov 5, 2020 | 05:09 PM
  #178
JakeW213's Avatar
W213 220d from 2016
yes quite a few things, but I had a very old one to begin with - not sure it has ever been updated before.
Old Nov 6, 2020 | 05:53 AM
  #179
Audrick's Avatar
W213 2017
After updating, does your car now have a Multicolor Ambient Light?
Old Nov 6, 2020 | 06:30 AM
  #180
JakeW213's Avatar
W213 220d from 2016
it does not, the look of the screen showing it has changed... but I can still only have one color at the time
Old Nov 8, 2020 | 03:06 PM
  #181
sabre3's Avatar
E300 4matic
Are these updates available for all years? My 17 E300 has the old version (00.61.00.20) I asked my sales guy if there were any updates after reading this thread and he said it was up to date.
Old Nov 8, 2020 | 03:15 PM
  #182
JakeW213's Avatar
W213 220d from 2016
He is lying to you. My car is older than yours and has gotten the newest update
Old Nov 8, 2020 | 03:17 PM
  #183
sabre3's Avatar
E300 4matic
LOL, ok good to know. Is this dealer updated or can it be pushed to the car thru the unit itself? Thanks
Old Nov 8, 2020 | 03:24 PM
  #184
ua549's Avatar
Dealer must do the update. It is not a trivial task.
My '18 E300 has 05.00.80.20. I have no issues so why update? AFAIK the updates fix bugs that occur with certain feature combinations not provides new features. Updates remove discovered bugs and hide new ones.
Old Nov 8, 2020 | 10:43 PM
  #185
nycebo's Avatar
2021 Mercedes Benz e450 Wagon
Did it fix the horrible google assistant voice interaction on Android auto? It keeps getting muted on my car
Old Nov 9, 2020 | 03:34 AM
  #186
JakeW213's Avatar
W213 220d from 2016
its mostly bug fixes and improvement to how it runs.... like most updates to most things. But it does add features. My 2016 model was not able to run MB navigation alongside carplay(they probably thought one would use carplays navigation) but now it can.
it had also mapped buttons differently plus the touch buttons on the steeringwheel now works with carplay(previously only the media dial would interact with carplay)
and for the bugfixes... it runs much more smooth and fast now. So a very welcome update for me
Old Nov 9, 2020 | 08:04 AM
  #187
ua549's Avatar
I don't use anything other than Android that Google has touched, same with Apple.
Old Nov 12, 2020 | 01:59 PM
  #188
SpaceDesign's Avatar
2017 E220 Estate & 2012 E200 Saloon
JakeW213 is your Easy Entry feature working? Mine is not on 4.080. my steering wheel used to rise up and away when I turned off the engine or entered the car, but now it doesnt, wondered if its fixed on your version?
Old Nov 12, 2020 | 04:32 PM
  #189
ua549's Avatar
It is still not working in 05.00.80.20.
Old Nov 13, 2020 | 04:20 AM
  #190
JakeW213's Avatar
W213 220d from 2016
I wouldn’t know as my car does not have this feature to begin with - But I guess that ua549 answered your question.
Old Nov 17, 2020 | 08:43 AM
  #191
velryba's Avatar
E220d
Hello...
software version: 00.59.03.20
last week I got my car back from the dealer (MY16 W213 220d). My easy entry started to play up, steering wheel would not go down sometimes after start up.
Also problem with windows not closing up in auto mode (had to hold the button up) and one wheel pressure sensor is telling me that I have a flat tyre, but I don't.
They have told me that they have updated the software to fix the easy entry problem.
I do not think they have updated it or have they?
Old Nov 17, 2020 | 11:23 AM
  #192
Egonvdv's Avatar
EQE SUV AMG-line 350+
as mentioned here above the software is (at least ) at 05.00.80.20, so it seems you have a very old version - IE: they did not update anything
i had several updates since i got the car 3 years ago and are now at 04.80.00.20 - so stil higher than you...
Old Nov 17, 2020 | 01:32 PM
  #193
velryba's Avatar
E220d
As I thought, but wanted to have another "independent" opinion before I would say out loud.... Why the FrontDoor would you tell me that you have made a software update, when you did not.... And why the **** did you delete the memory on my seat preset??????
It took me so long to find the perfect position and now I have to do it again...................................
Old Nov 17, 2020 | 03:48 PM
  #194
ua549's Avatar
You should backup all of your personal settings in your profile using the profile backup menu.
There is a thread that explains how to do it.
Old Nov 18, 2020 | 05:27 AM
  #195
velryba's Avatar
E220d
1st time I'm hearing about this.
Will definitely look into it.
Thank you.
Old Dec 2, 2020 | 05:00 AM
  #196
pepa1346's Avatar
w213 E300
in order to support the multicolor ambient light, command update is not enough. There is a possibility to open the menu item, but it won't work, you need to do coding in the block under glovebox. Don't remember the name, starts with HLxxx. The easiest way is to find a car with that function, backup coding bytes, and upload into your block. 1 hour work, should cost 100$ No SCN coding required.
updt: I was replying to https://mbworld.org/forums/e-class-w...ml#post8196346
Old Dec 23, 2020 | 11:23 PM
  #197
LogS's Avatar
2017 E300 (w213)
2020 Update
I've been following this thread for a while.
I have a 2017 E300 (w213) on 00.61.00.20 and after months of back and forth with the dealership about the update and how I had the latest and how new updates could cause problems and bugs, I pushed them and got the update to 5.80.00.00.
Things I've noticed so far as some were stated in previous posts
Positives
  • Bigger Icon home menu
  • Ability to turn off NFC
  • Caller ID in HUD
  • Battery remaining of connected bluetooth phone on the top right of the screen
  • Updated ambient light screen
  • Slightly faster interface/boot
  • Meshed side cameras during parking assist
  • Slightly better navigation menu
  • Better sound processing and loudness (better quality)
Negatives
  • Android Auto still 2/3 screen
  • Easy entry/exit still steering wheel only
Overall I would absolutely recommend the update, these are the things I've noticed so far and will update if I find more.​​​​​​​
Old firmware
New firmware
Larger icons
Meshed side cam view
Battery in the corner
Old Jan 26, 2021 | 06:29 PM
  #198
beechcamp's Avatar
2025 E450 All Terrain Wagon, Nautical Blue Metallic, Macchiato Beige/Black Interior
Thanks for the info, folks! I've "lurked" on the forum for a few years and decided to join today.
Anyhow, I brought my 2017 E300 in for Service B today and mentioned "static" in the Command system. My SA immediately and without any push from me updated the software and it is, as described in previous posts, a very nice upgrade for 2017 model. It's very nice to use steering wheel controls on Apple Car Play. Interesting side effect: my auto stop/start is much more responsive in that it engages more easily at stop lights, etc. Whether that is good or bad I'll leave up to the individual reading the post - I'm sure there are lots of opinions on that function!
Old Jan 28, 2021 | 08:29 AM
  #199
velryba's Avatar
E220d
Just to update.
I have received the "2018" update now(5.80.0000000000..... ), as it had to be done for my personalisation to work correctly.
Windows problem was down to old battery.
Now it starting to look like all bugs are gone......
Old Feb 1, 2021 | 09:07 PM
  #200
Atilio's Avatar
2018 E400 4matic coupe
