E-Class (W213) 2016 - 2023
Changing US spec Intelligent Headlights to Euro/UK spec
Old Nov 14, 2018 | 04:07 PM
checkmarsahll's Avatar
2018 E300W4
Is there a software change or update to enable full intelligent LEDs in the new E-Class with the ILS? (P02)
Old Nov 14, 2018 | 04:26 PM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
In the US? At this time there is not. Only recently has the NHTSA even recommended the use of the European system to use the full intelligent lights and it still has to go for public comment and full ratification before completely permitted. Then we have to see if we even have the very same lights in our cars they do in Europe AND if MBUSA will consider offering reprogramming of our lights if we do.
Old Nov 14, 2018 | 09:34 PM
2012 merc amg's Avatar
2018 S560
I think we are SOL on this one. It's a shame because we pay extra for the lights and then can't really utilize them, oh well, at least the lights are pretty good as they are.
Old Nov 14, 2018 | 10:03 PM
rbrylaw's Avatar
I suspect you are right. MB doesn't seem to like to reprogram things after the sale. I would be more than willing to pay for a reprogram if it becomes reality that we can finally have the same lights they have in Europe.
Old Nov 15, 2018 | 06:33 AM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
I sincerely doubt they put a different light system in US vehicles, it's probably a software update of some kind. I'm sure once the NHTSA bs has run it's course, if not MB, someone will figured out the software necessary to get it up & running.
Old Nov 15, 2018 | 09:22 AM
rbrylaw's Avatar
I hope you're right on all counts. While I think the Intelligent Lights are already fantastic, better would be icing on the cake!
Old Jan 12, 2019 | 08:00 AM
jl199986's Avatar
'20 E Wagon
Where’s the hackers? I would pay for this. Is it a setting in engineering mode possibly?
Old Jan 12, 2019 | 10:34 AM
rbrylaw's Avatar
I would suspect hacking into your car's programming could void your warranty?
Old Jan 12, 2019 | 11:38 AM
wdimagineer's Avatar
E 53 Wagon
*waves*
I’ve done the conversion. It required new hardware, access to factory diagnostic tools, factory software, and lots of trial and error. There are dozens of steps required including flashing numerous control modules. I made a few mistakes and thankfully have SCN access to code my car back to stock automatically.
Old Jan 12, 2019 | 11:53 AM
rbrylaw's Avatar
Originally Posted by wdimagineer
*waves*
Are you in the US? What hardware is required? That is disconcerting as I had hoped once fully approved for the US market, dealers would be able reprogram our intelligent lights to the new spec.
Old Jan 12, 2019 | 12:03 PM
E 53 Wagon
Yes, I’m in the US. I hope once the regulatory environment changes you’ll be able to activate the functionality. Until then, no software exists for US-spec headlamps.
Old Jan 12, 2019 | 12:19 PM
rbrylaw's Avatar
You said it required new hardware. What new hardware is needed?
Old Jan 12, 2019 | 12:32 PM
jl199986's Avatar
'20 E Wagon
Thanks WD. Reading up on your E63 exploits. While I've got "above average" skill from modding VW's thru VCDS and even ECU software I've tweaked myself- I'll hold off on this for now. My first MB.
The $takes with MB are a bit higher to fix my mistakes. And I've not got ample time these days. So for now the combination of hoping for US relief and running my warranty out a good bit longer should give me pause to wait.
We'll see how long that lasts.
Old Jan 12, 2019 | 12:35 PM
jl199986's Avatar
'20 E Wagon
I think he means a new headlamp unit with a EU spec serial number that MB software recognizes. That's the challenge with intelligent (chipped) hardware- not necessarily interchangeable even if the actual hardware is the same- if the chip says it's different- it's different.
Old Jan 12, 2019 | 12:53 PM
E 53 Wagon
Exactly.
Old Jan 12, 2019 | 02:34 PM
E 53 Wagon
You can follow along on Instagram: jaronbrass
I’m known for my retrofits on BMW, VW, and Audi. This is my second Mercedes and the first I’ve tweaked.
Old Jan 12, 2019 | 02:41 PM
Cao Black's Avatar
2015 ML350+2025 E350
This may be a moot point as it appears MB is already adopting a new design. See my post about "New Headlight Option". They're not likely to upgrade any old designs. Hackers notwithstanding.
Old Jan 12, 2019 | 03:10 PM
E 53 Wagon
The new design is C only and is the base model LED with no adaptive features.
Old Jan 12, 2019 | 03:14 PM
rustybear3's Avatar
The long and short of it sounds as if the majority of us are SOL. I too was hoping for just a software update. If this requires different headlamps, then there is no way MB is going to switch out us previous owners.
Old Jan 12, 2019 | 05:33 PM
E 53 Wagon
It shouldn’t require new headlamps. Right now, it does, because there’s no software.
Old Jan 12, 2019 | 05:39 PM
rustybear3's Avatar
So, if the proper software was available, no additional hardware would be necessary in order to convert....correct?
Old Jan 12, 2019 | 05:41 PM
E 53 Wagon
Correct. Let’s hope the option becomes available.
Old Jan 12, 2019 | 06:49 PM
ua549's Avatar
MB is not known for retrofitting software to older models. If there is an upgrade it will most likely be in the E Class refresh.
Old Jan 12, 2019 | 07:23 PM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
Perhaps not new software, but they do embed a lot of options in OEM modules that can be activated with the right tools. I had active fog lights and tire pressure monitoring (ABS-type) turned on in my old W203 AMG C55.
Old Apr 22, 2019 | 09:27 PM
jhpmbusa's Avatar
2021 M550i
https://www.autoblog.com/2019/04/22/...ve-headlights/
seems like we may get clearance in the future for European spec headlights...
