Gliding Mode
My June 18 W213 now has 3,000 KMs on the clock and so far I am pretty pleased but I am seeing some oddities which I cannot explain but some of you might be able to shed light on. Before I describe the oddities and ask questions, please note that I leave my house at 6:40am every weekday drive 40kms to work (no traffic). I also leave the office at 5:00pm when there is usually traffic and take the same route home (90% highway)
- Does the Engine Auto Stop/Start setting influence whether Gliding Mode is turned on or not. I have seen Gliding Mode with Auto Stop/Start at the on and off positions whilst in E driving mode. I had previously read somewhere that the Auto Stop/Start was also a switch for Gliding mode - not sure if that is true.
- When the car in in E mode, the Gliding mode on some days never gets turned on at all but on other days, it does. As mentioned above, I drive the same route each day at the same speeds ( 70 to 100 km/hour ) with a very gentle foot. Why is this ? same route, same speeds, dry weather, same temps ( 25 Deg C ) and no traffic.
- On the way home from the office, Gliding Mode nearly always engages when the road is ~ 15 meters clear ahead regardless of the incline or even light traffic ahead. What baffles me is the road conditions on the way to work are close to perfect for gliding but the car only engages 40% of the time where I would expect it to whereas on the way home, it engages closer to 80% of the time where I would expect it to.
- When I turn off the Auto Start/Stop hoping it disables Gliding mode at some sections on the way home, it does indeed turn off Gliding mode.
This is a bit baffling.
Oddities aside, I am seeing great economy from my W213 - petrol. It's matching the economy of my wife's car which has a smaller engine and 50% less HP and 25% less weight.
So say you're driving at 50mph exiting a highway, it'll recognize you're doing that, the engine will shut off, the transmission will then switch to coasting mode....etc.
That's my guess. I bet you the OP is not from the US as even with Audi, that feature is turned off here in the new 2019 models until the car comes to almost a complete stop.
In my ‘braking in’ period it seems to be doing it a lot.
We have ’Glide’ mode when economy setting is selected. On motorways or other roads where active acceleration is not required it deselects the drive train and allows the engine to idle thus supposedly saving fuel.
https://media.daimler.com/marsMediaS...ml?oid=9905259
Maybe the different terms are country dependant?
I will ask MB tech when I pop in for the first service as there are obvious more factors being considered when the car decides to put the car in "gliding mode". Speed, road incline, traffic, working temp, driving style are definitely not the only factors and my Auto Stop/Start button has no effect as gliding mode activates regardless of what the setting is when I am driving in "E" mode. There may be a software or sensor glitch or it might just be normal - whatever the explaination is, I am curious as the apparent randomness baffles me.
Owners manual
Dash display
Things I've noticed:
1) The car's engine needs to be fully warmed up
2) The battery needs to be fully charged
3) The first time I engage it seems to be ~45mph or higher
4) Distronic/Cruise control won't ever use it.
5) If you pull up the Vehicle Data screen on the entertainment screen (has steering degrees & gas/brake pedal positions), it'll do a fancy animation on the car when you're in gliding mode.
6) It likes to see a clear, intentional let off the gas. Gently throttling back doesn't seem to trigger it.
- If am above the set limit: for example I have set the limit at 70 and I am going 75 and take my foot off the gas, glide mode engages until I reach 70: and
- For example going down hill: this often happens as I travel in Vermont in the mountains.
It is pretty cool to watch the gear indicator go from "9" to green" D" and the RPM's drop from 1800 to 750 RPM. Glide mode, as indicated above, does not work in comfort mode.
