E-Class (W213) 2016 - 2023
Only the e43/e53 version have ambient light at the top of the LCD screens right?
Old Feb 19, 2019 | 08:58 PM
jasonqw1's Avatar
kjn
I have noticed my e450 doesn't have it, they should really do a better job documenting this.
Old Feb 19, 2019 | 09:30 PM
Cao Black's Avatar
2015 ML350+2025 E350
If you have digital gauges and COMAND you should have ambient lighting above the wide screen displays. Analog gauges do not...unless there were changes for MY 2019.
Old Feb 19, 2019 | 09:33 PM
jasonqw1's Avatar
kjn
I have both, but from what I can see only the bottom part of the screen has ambient lighting?
Old Feb 19, 2019 | 11:07 PM
Cao Black's Avatar
Might have to wait for 2019 owners to respond then. Meanwhile you might double check that the intensity is turned up sufficiently.
Old Feb 19, 2019 | 11:18 PM
jasonqw1's Avatar
kjn
Huh mine is also a coupe, not sure if that changes anything. Also I thought command comes with all e-class vehicles now? There is no option to get command on the mbusa website.
Old Feb 19, 2019 | 11:25 PM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
I have a 2019 E450 CAB with both digital gauges. I have the upper ambient light. Have confirmed with fellow 2019 E members (CAB & non-CAB) that if you have analog gauges, you don't.
COMMAND NAV is standard on e-class vehicles.
Old Feb 20, 2019 | 12:23 AM
Cao Black's Avatar
Roger that. Wasn't sure if it is standard everywhere, and OP doesn't indicate his location.
Old Feb 20, 2019 | 03:22 AM
JDPEClassUK's Avatar
E Class Estate S213
I have a MY 2019 Estate with both digital gauges and the ambient light is top and bottom
Old Feb 20, 2019 | 06:40 AM
sackboydad's Avatar
2019 E450 Cabriolet, 2020 GLS450
My 2019 e450 Cab has lights at the top of both displays.
Now... why they didn’t give us more control over the lights is another story (why do I have to use MB color combinations? Why can’t I set exact colors of each zone of lights? Or why only 2 zones? Why can’t I set the color of each air vent? If I want to make my car look like a unicorn puked well... maybe I wanna! 😬&#128556
Old Feb 20, 2019 | 07:29 AM
stephos's Avatar
MY19 E450 4MATIC Coupé
Mine is a MY19 Coupe and it has the ambient lighting on top of the displays.
Old Mar 8, 2022 | 02:46 PM
r3dbenz89's Avatar
W213 E53 | 992 C2 | G20 330i
Resurrecting an old thread here but I was wondering about this too...mine is a 22 E53 sedan and it DOES NOT have the LED strip above the LCD cockpit screens...just below. It seems like they may have deleted the strip above after a certain point...like the LED lights inside each door handle are also gone, the missing analog clock, etc. Now there is an angled led light underneath each side view mirror that lights up the area in front each door.
I forgot about the LED strip above the cockpit until I rode in a buddy's W222 S Class and I was reminded.
Old Mar 8, 2022 | 07:49 PM
kingscorpian27's Avatar
MB W213 E300 4MATIC Luxury Model
I have a MY 2017 E300 and I have both above and below the screen
Old Mar 9, 2022 | 09:45 PM
r3dbenz89's Avatar
Just read on another thread that potentially the factory forgot to plug in a harness if the top of the cockpit screen is NOT lit....sounds like too much of hassle..
EDIT: confirmed after 22 MY ...only the bottom portion of the wide screen is lit...for whatever reason the top portion was deleted.
Old Apr 3, 2022 | 01:13 PM
amgluvr2's Avatar
2021 E450 All-Terrain
Our '21 All-Terrain does not have ambient lighting above the screen
Old Apr 3, 2022 | 07:49 PM
W205C43PFL's Avatar
Unfortunately, it seems like the facelift removed the top one as they think people don't notice?
