Device Not Supported Message
this is not a mini card right? (cos in such case sometimes the adaptor can cause problems)
I'm using a 64 GB memory card that works fine. BTW they are all San Disk cards.
Question: If one resets the system, I know you have to re-pair blue tooth phones again. Would you have to re-establish the ME Connect all over again as well since it erases previous data?
Do I need make update of the car to fix this or also this System Reset ?
Just had a few quick questions please in regards to what are the limitation of the info system in my model?
Ive got a spare San Disk Extreme SDXC 128gb card...would that work?
Do all songs need to be in mp3 format only?
My COMMAND system has the PCmcia slot that then offers the SD card slot through it.
Thanks in advance!
A 128 GB card will work.
My music is in flac format.
My video is in mp4 format.
The disc is a SanDisk Extreme Pro 32 GB.
Ive been trying to find info on the older command system limitations with SD card music but have not had much luck hence why when i found this thread ( even though its the current gen E Class) id thought id ask incase anyone knew about the older system.
Some people i have asked said it only will work with up to 32GB file size card while others say 64GB is fine. Some say all songs have to be .mp3 while others say any format is fine :/
Just FYI, I recently downloaded all of my music to an SD card (Sandisk Extreme Pro 32 GB) as ALAC files (Apples' version of FLAC). Just tested it out and it played perfectly. Probably doesn't help any, but not sure why you would get that message for your 32GB card.
