Trickle chargers and the new 3.0 48V system...
Considering a new W213 "All Terrain" wagon and have a question.... In the past, I've sometimes had to park my vehicles for several months when traveling (when we all could). I always kept them on a battery tender in a garage. Kept the batteries in everything happy! Now, with the new W213 with a 3.0, it has a dual voltage system, from what I gather. A 12V for all the auxiliary stuff, and a 48V that I assume actually starts the vehicle. If I have to put this thing in lay-up mode for several months, and use my traditional 12V batter tender hooked to the jump lugs under the hood, does any of that "trickle" make it's way into keeping the 48V system charged or am I simply keeping the 12V system happy (another words, I'd have lights and radio, but no juice to spin the engine over)? On another more obscure possibility, what about jump starting these things? In glancing over the owners manual it seems one would again use the 12V jump lugs so I am assuming there must be some kind of step-up voltage happening somewhere in the system to get juice to the 48V side that actually spins the engine over? Did a search, can't seem to find anything....
point of the 12 V battery (/ page 311). The 48 V battery is charged via the voltage converter in the vehicle." A similar reference to jump starting the vehicle on page 311 also seems to state something along the lines of connecting the jump leads to the 12V lugs and waiting for a few minutes for the voltage converter to juice up the 48V system, then start the car. So it would APPEAR that a 12V Battery Tender could be used during storage (of course the manual states to use an "approved" MB charger, which really looks like a regular, rebranded C-TEK unit and is 12V) and it indeed will dump juice via the "voltage converter" into the 48V battery. Can't imagine it a very efficient way to juice the 48V system going through some kind of step-up transformer or something, but it appears that's how its done.
The 48v battery is normally charged directly by the 48v starter/generator.
Ctek makes the banded name charges for many cars, Porsche and Mercedes included. You can buy a Ctek charger or pay double for the same charger that has "Mercedes" printed on the outside.
As M_Austin correctly points out in post #8 the battery charger charges the 12 Volt batter which in turn keeps the 48 volt lithium battery charged.
A Ctek charger will do just fine!
I've owned a Ctek charger along side of my favorite Battery Tender charger for 20 years.
As per post #8 a Ctek battery charger will charge the 12 volt battery and that 12 volt battery will maintain the 48 volt battery as well.
No one has suggested using a charger to charge the 48 volt battery - nor as post #8 points out is there any need to: a 12 volt Ctek battery charger will do both!
Also, I had a CTEK charger fail on a vehicle. The consequence was buying a new 12 V battery. I hate to think what the cost would have been with a lithium 48 V battery.
Further, Weather Tech and Costco sell a battery manager not from Ctek, but sourced in China.
Still, I expect we will see a lot more on this issue. I would not put an EV in storage with what I know now, and I am not aware of this issue being addressed.
That to me is the simple and complete answer. Let's not try to "fix" something that is not broken - how to charge independently the 48 volt battery. By charging the 12 volt with a high quality Ctek charger you will also maintain the 48 volt battery.
Good luck getting Mercedes to put:
"So it would APPEAR that a 12V Battery Tender could be used during storage" Emphasis in original.
"APPEAR" would not be good enough for me. As to getting something that you can rely on, I expect getting anything in writing out of MBUSA is impossible. So you play their game. You send them a letter saying "your guy told me and I am relying on it."
I for one, am not holding my breath!
I expect the constant drain for telemetry and such is why Mercedes Me Connect always says "starter battery partially charged." That is why I lock the car even the the garage, thinking I am minimizing the drain. Is there a hibernation mode on our cars and if so where?
