E-Class (W213) 2016 - 2023
air Pessure
Old Jun 30, 2021 | 02:55 PM
tomd's Avatar
2025 E450 4Matic
air Pessure
I recently purchased a 2021 MB E450 with the 19" AMG rims fitted with P245/40 R19 XL 98h Pirelli CINTURATO P7™ ALL SEASON PLUS II Run Flats. My question concerns the proper tire air pressure
The sticker on the gas cap suggests 36 front, 36 rear
The sticker on thr B pillar suggests 41 front, 47 rear
Any ideas? Thanks
Old Jun 30, 2021 | 03:35 PM
JakeW213's Avatar
W213 220d from 2016
Somewhere between the 2?
I run 260 psi/ 2.6 Bar on my staggerede setup
245/35-20 and 275/30-20
Old Jun 30, 2021 | 03:40 PM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Any ideas? Thanks
If you look closely at the B-pillar notes, I seem to recall that's the maximum pressure. I don't know why they do that now (wasn't always the case) but hey I'm no expert.
Old Jun 30, 2021 | 03:53 PM
konigstiger's Avatar
'71 Pinto
I believe tire reads maximum pressure 50 psi. B pillar may be best.
Old Jul 1, 2021 | 07:14 AM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Use the tire pressure on the gas cap. I always add 10%.
Old Jul 1, 2021 | 09:49 AM
TPAbnz's Avatar
2017 E300W
Same issue here. If pressure is set to gas cap numbers, the low tire pressure warning comes on. Was told by dealer to use the pillar sticker values.
Old Jul 1, 2021 | 12:13 PM
benz 4 jts's Avatar
00 ML430, 00 E320 4matic wagon
The tire pressure listed on the gas cap is the proper pressure. A lot of tire shops get confused by that. see the attached.
File Type: pdf
Old Jul 1, 2021 | 03:49 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
TPMS pressure setting can be adjusted for whatever target pressure you want... so if you want to use the filler door, set the pressures COLD and thru the IC reset the TPMS pressure to your "new" values.
