E-Class (W213) 2016 - 2023
New E450 wagon wheel change
Old Mar 7, 2022 | 12:25 PM
CAPTKIRK's Avatar
2006 R500
Long time reader, first time posting :-)
I picked up this car new last week and so far, things are going great.
I was offered a set of brand new 2018 S600 rims for free! (part # 2224010400 and 2224010500)
My Wagon came with 19" rims with 245/45/19 tires front and back. The new rims (same bolt pattern) are staggered size front- 245/40/20 and rear-275/35/20.
The MB dealership parts guy said "just try them on".
My biggest concern is:
-do you think the offset will fit?
-there is a slight circumference difference between front to back, will that mess with the AWD system?
-will the staggered rim size make a tracking difference?
Thank you in advance for any help or comments that you may have!!!!
Old Mar 7, 2022 | 03:33 PM
Eraser-X's Avatar
21 E450 Wagon and 07 SL55
Offset is on the back of the wheels as an ET number. You may need spacers and longer bolts. My question is why go to a staggered set up and loose the ability to rotate your tires and give up the treadwear warranty.
Old Mar 7, 2022 | 04:07 PM
CAPTKIRK's Avatar
2006 R500
Thanks for the comment! I am just trying to decide if it makes any sense to utilize a set of nice free wheels.
Old Mar 7, 2022 | 05:41 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
The ride with the 19" will be harsh enough: IMO, the ride with the 20" will be rock hard and even the smallest pothole may damage both your tires and rims.
Old Mar 7, 2022 | 07:08 PM
Mac Jones 55's Avatar
E450 presently.
Get what you want, obviously.
Old Mar 7, 2022 | 07:19 PM
JTK44's Avatar
The OP was asking for advice: What is yours?
Old Mar 8, 2022 | 07:03 AM
Janster's Avatar
E450 4Matic Wagon '19, MDX '09, 9-5 Aero '03, 280ZX '79, BelAir '57, VF700S Sabre '84
Congratulations on your new longroof!
According to the wheel part numbers they are:
2224010400 - 20 X 8.5 - OFFSET 38
2224010500 - 20 X 9.5 - OFFSET 38
The wheels will fit fine in your wagon. I have a the same size wheels with 35mm offset and I like the fit (would not be able to tell the difference of 3mm from your 38 offset). No spacers or longer bolts required.
The next questions are the tires. With 4matic you want the tire diameter to be as close as possible. I read somewhere it should be within 1% (but I am not an expert).
Your tires are:
245/40/20 - 704mm in diameter
275/35/20 - 701mm in diameter
that is 0.43% difference, which has to be good. I am not sure you can get closer than that with staggered tires without going to the same size tires all around.
I like the look of the wagon much better with the 20" wheels. Yes, you need to do more smooth road surfing and avoid any potholes to minimize the chances of a disaster.
Old Mar 8, 2022 | 04:41 PM
AR_motorwerkz's Avatar
MERCEDES AMG GT, MERCEDES CLS63 AMG, MERCEDES G63 AMG, MERCEDES CL63 AMG
Just gonna drop our customer’s e63 estate on LMs!
Old Sep 6, 2023 | 09:39 AM
rogeral's Avatar
E450 All Terrain
Did you ever mount these wheels? If so, do you have pics you can share?
Old Sep 6, 2023 | 09:41 AM
rogeral's Avatar
E450 All Terrain
Your tires are:
Janster - can you please share pics of your setup? What size tires do you have? Thanks!!
Old Sep 6, 2023 | 12:03 PM
Janster's Avatar
Same tire size on all 4 wheels, no issues with fit or handling.
255/35ZR-20
Old Sep 6, 2023 | 12:23 PM
rogeral's Avatar
E450 All Terrain
255/35ZR-20
Very helpful, thanks so much!
Old Sep 6, 2023 | 01:25 PM
Roweraay's Avatar
X214
I have a 19” staggered setup (from the S-class) on my ‘22 E450 wagon. Tire sizes are 245/45/19 (front - same as the standard size) and 275/40/19 (rear). Absolutely perfect bolt-on fitment.
Front wheels are 8.5” wide, while the rear wheels are 9.5” wide. The width and offsets are near identical to the 20” optional wheels that come on the E450 All-Terrain, which probably accounts for the perfect fitment.
Old Sep 6, 2023 | 01:48 PM
rogeral's Avatar
E450 All Terrain
Your setup looks great too - do you happen to recall/know the offset of the S class wheels you are using? Thanks!
Old Sep 6, 2023 | 02:59 PM
Roweraay's Avatar
X214
The 19x8.5 has a 36mm offset and the 19x9.5 has a 43.5mm offset
Old Oct 14, 2023 | 05:49 PM
Novasteve's Avatar
E450 wagon
255/35ZR-20
any more pics? Are you on instagram by chance?
Old Oct 14, 2023 | 06:13 PM
JTK44's Avatar
255/35ZR-20
Wouldn't work north of the Mason-Dixon line with snow and pot holes!
Old Oct 25, 2023 | 01:19 PM
rogeral's Avatar
E450 All Terrain
Thank you for all the helpful feedback on this thread.
I purchased some 20” S63 wheels for our new All-Terrain wagon. The fronts are 8.5” wide and the rears are 9.5” wide, and the offset of both the front and rear wheels is 38. Tires are 255/40 in the front and 285/35 in the rear.
I installed them for test fitment and drove a couple hundred miles. They fit amazingly, give the car a much more aggressive stance/look, and I noticed no issues with rubbing or any other downsides. I personally think the wider setup is how the car should have come from the factory…
I didn’t get many pics prior to removing them for the fall/winter, but can take more in a few months if anyone is interested
Old Dec 6, 2025 | 03:31 PM
Sightlinereader's Avatar
2022 E450 All Terrain
W213 All Terrain 19" Wheels
I needed a set of wheels for my dedicated winter tire set up. I wanted an MB factory wheel rather than aftermarket so if I damage one, I can get a replacement. The All Terrain standard wheel is a 19"X 8" with offset of 38mm. Turns out the GLC 19" wheels have the same bolt pattern, hub bore and ET. Scored a set of 19" MB wheels off a GLC that should work great. Added bonus... They are closer to the optional 20" wheel in appearance which I prefer. The wheel is model 560-85483. Hope this helps other AT folks looking for a 19" wheel. There are other 18" and 19" options to from a GLC that should bolt right up and are ET 38 too. Use reading glasses? Check out Sightline Readers - my day job.
GLC 19
GLC 19" wheel 560-85483 on All Terrain
