Cigarette lighter question
Is there such a fuse on a W213 and if so, which fuse is it?
Does the UBS port remain alive after the ignition is turned off or does that go dead as well?
Thanks.
https://www.amazon.com/dp/B0D3M6K9BS...lxgnl8YhU&th=1
No, actually you can just leave the trickle charger outside the car and close the door on the thin wire that goes from the charger to the USB port. On my Porsche 911 (where the cigarette lighter is live continuously) I've been doing this for years.
Thanks for your thoughts.
Interesting points about the UBS being 5 volts and the trickle charger being 12 volts.
Now the question is whether my CTEK trickle charger will work in the UBS slot: the question: 12 volts going through the UBS port.
I have a quick connect pigtail connected just underneath the plastic cover in the engine bay where there is a negative terminal and the positive post (with a red slide cover) for jumping the battery. I then place the pigtail nearby the wiper but tucked away just underneath the hood. I did this on my last vehicle and had no issues.
I just did a Google search and came up with the following:
No, a standard USB port alone cannot power a typical car battery trickle charger because the voltage output from a USB port is too low (usually 5 volts) compared to the 12 volts needed to charge a car battery; therefore, you would need a special adapter to use a USB port to power a trickle charger for a car battery.
Key points:
- Voltage mismatch:
A standard USB port only provides 5 volts, while a car battery requires 12 volts to charge properly. - Current limitations:
Even if you could somehow adapt the voltage, the current output of a standard USB port might not be high enough to effectively trickle charge a car battery.
There is no good way. The output of a USB port is a tiny fraction of the power needed to charge a car battery. A car battery might hold 80 Amp Hr at 12 V. A USB 2 port can provide 0.5 Amp at 5V. So it is going to take something like 500 hours to charge up that battery - call it three weeks, assuming no losses.
see: https://www.quora.com/Whats-the-best...attery-charger
Regarding the quick connect suggestion, do you have to open the hood to access the quick connect? I did a similar thing in a Jaguar that I had where the battery was in the trunk. If I could easily access a positive post in the cargo area of my W213, I would do that. There's a fuse box on the right side of the cargo area behind a snap-out carpeted panel, but I didn't see a positive post to which I could attach a quick connect.
Key points:
- Voltage mismatch:
In this direction
Home AC Power -> Trickle charger -> cigarette to USB converter -> car battery
Not in this direction
USB Port -> Trickle Charger -> battery
Three complications I see in this. One is the USB to Aux that converts 5V to 12V. The second is the car's internal electrical system converting the 12V to the 5V for the USB port. Lastly, there may be circuits in place to prevent doing this so it doesn't damage sensitive electrical circuits. I seriously doubt a USB port has a direct path from the battery like some auxiliary outlets may have. Ther are likely some additional electronics in between since it's not just a power port but also data to the entertainment system. All I can say, is that I would never even think about doing this. Then again, I never thought you could use the auxiliary ports (cigarette lighter) as a route to the battery so what do I know. For the auxiliary port, it makes more sense since it's 12V and just power. The USB port is a data port that only has 5V for power. Very different animal.
I'm traveling at the moment so I can't snap any photos for upload.
