E-Class (W213) 2016 - 2023
W213 2016 ambient light stuck on purple wont change colour
Old Mar 25, 2022 | 08:13 PM
ASIMM387511's Avatar
2016 w213 mercedes e220
Hi everyone need a bit of help
i have a w213 e220 last night when i parked my car my ambient light was on blue which i keep it all the time ,woke up this morning started my car and lights were automatically purple ,and now when i go to change the colours is stays on purple any idea on what it could be ,when i go to the ambient lighting option it shows the lights are on white but the lights are stuck on purple
Old Apr 11, 2022 | 10:16 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W213 forum...
Old Apr 13, 2022 | 06:35 PM
NbyNW's Avatar
Veteran: Navy
Various
Reboot the command system (hold on/off button on center console for 30-60 sec until command reboots) or disconnect the battery might help. Rebooting any computer seems to fix many problems. What I’d try, not an expert on the 2016.
Old Apr 15, 2022 | 03:49 PM
SpeedracerZ06's Avatar
2018 E43
There is a setting called "Adjust Ambient Lighting" that turns on the bright purple color overriding what you have configured. I stumbled on it the other day and click on the setting wondering what it does. I think it's for adjusting the ambient light intensity. It's buried inside the System menu. You want to uncheck the box to turn off the override. I'm going by memory but I believe its under designs sub-menu but not positive.
Old Apr 15, 2022 | 10:32 PM
W205C43PFL's Avatar
In that case, if OP couldn't find it, they could consider restoring settings.
Old Apr 16, 2022 | 07:01 AM
ygmn's Avatar
2015 E400 Sedan
car is LSU fan is all.
Old Nov 22, 2022 | 03:21 PM
w213coolguy's Avatar
w213 - 2019
what does this mean?
I have the same issue, on multicolor its working but when i want to have complete red or green (or.any.other color) it doesnt change and stay on purple. I tried command restart and factory setting already...
Old Nov 22, 2022 | 03:50 PM
GPF's Avatar
GPF
2018 S450 4-matic W222
LSU primary color is purple.
Old Nov 22, 2022 | 05:33 PM
w213 - 2019
thank you for yoir reply!
but how.can i fix this provblem?
when i scroll to whichever color, it stays purple..
Old Nov 23, 2022 | 08:34 AM
JakeW213's Avatar
W213 220d from 2016
did you try any of the above mentioned suggestions? Most likely its a software problem, so a reset might clear it. Alternatively you could look into a firmare update of comand?
Old Nov 27, 2022 | 01:15 PM
w213 - 2019
Hello sir,
I Tried the reset 60 sec, but wasnt the solution for me. I have also reseted everything to factory settings in command but still same problem
What could possibly be wrong ?
Old Nov 27, 2022 | 01:20 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Do you have a w213 or a 2016.
In the US the w213 was not available in 2016. It was a w212 in 2016. Please clarify your year, model, and location. This will help the forum help you. Is the color changing system stock or aftermarket? Aftermarket is available for w212 to kind of match the possibilities of the w213.
Old Mar 1, 2023 | 05:18 PM
zdgamin1's Avatar
2017 e300
I have the same problem any fix?
Hi everyone need a bit of helpi have a w213 e220 last night when i parked my car my ambient light was on blue which i keep it all the time ,woke up this morning started my car and lights were automatically purple ,and now when i go to change the colours is stays on purple any idea on what it could be ,when i go to the ambient lighting option it shows the lights are on white but the lights are stuck on purple
Old Mar 2, 2023 | 10:52 AM
zdgamin1's Avatar
2017 e300
i can't believe no one has a simple fix for this i dont want to go to the dealer just because my lights wont change colors .
Old Nov 7, 2023 | 12:41 PM
w213 - 2019
Anybody a solution to this?
Old Nov 7, 2023 | 04:06 PM
La0laEsMia's Avatar
2024___
purple is the best color, but yea. kind of annoying.
Old May 16, 2024 | 09:36 AM
groovetek's Avatar
2017 E43 AMG
​​​​​​Same here, just picked up a 2017 E43 AMG, and if I disable multicolour node and try to select a single colour, it keeps reverting to Purple, Shade #28.
Seems most likely a software bug that is probably patched/fixed. Any ideas how to update firmware/software for the Comand system?
Old Aug 26, 2024 | 05:26 AM
AmbientCodingPL's Avatar
GLC 43 AMG Coupe
Had a customer come in for retrofitting ambient turbine air vents and 3d rotating tweeters, he had the same issue, coding fixed his issue, I can do this remotely as well would require you to have a windows laptop and open port 2.0 obd cable,
Old Dec 28, 2024 | 06:38 AM
ahm._.ixx's Avatar
2019 C43 amg
I have a 2019 C43 with the same exaxt issue stuck on purple shade 28 brightness 3 and 3. No matter what i tried i couldnt fix it, i tried everything mentioned and dissconnected the battery too and still couldnt fix it, anyone found a way to fix it??
Old Dec 28, 2024 | 07:05 AM
groovetek's Avatar
2017 E43 AMG
Yes, fixed it by going to the dealer to get the latest software available for the onboard computers.
Old Jan 30, 2025 | 08:08 PM
EleBest's Avatar
SPONSOR
E200 2010, G63 2018, E53s 2019, EQS53 Touring 2021, S500 2022, A200 2023
Can be fixed by remote coding in the same time we can do ILS+, upgrade 2016 to 2019 or 2021 ambient lights, *** memory, AC memory, High Speed 360 camera etc.
Cheers!
WhatsApp me at
https://wa.me/6597335000
