E-Class (W213) 2016 - 2023
No a/c …HELP!
Old Aug 6, 2022 | 10:14 AM
Mikew213's Avatar
Mercedes w222
No a/c …HELP!
Gm , this is my 1st time posting on this site, so I’m not sure if I’m posting in the correct section.
Any help would be greatly appreciated. So I had no issues with my ac, I have been using it fine for the past 2 months. After parking it one afternoon, I went back to run an errand and the ac wouldn’t start…the light on the ac button wouldn’t even come on. I plugged sentry onto the car and got a message that the vehicle has Lo refrigerant ,when I clear the message it comes right back. So I went and purchased a can of refrigerant but the compressor won’t activate to add refrigerant … I took the car to a shop and was told that the car has refrigerant, he checked the compressor and found no issue, but mind you this is no Mercedes’ expect. Not sure if it’s a sensor that’s getting a mixed message which is stopping the compressor from enabling… anyone been through this?
Old Aug 6, 2022 | 10:30 AM
SmokinJoe's Avatar
2021 E-350 Loaded
Possible failure of the Low pressure switch sensor.
Take car to dealer or a service that specializes in a/c repair.
Suggest posting your car information.
Old Aug 16, 2022 | 01:14 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 16, 2022 | 02:08 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
finish your job 👍
You have done all the right things... now just replace the pressure sensor/sw @SmokinJoe pointed out.
You won't need to vacuum the circuit if you're quick enough to swap!
No need parts?
Before anything look if connector contacts make/female are oxidized.
​​​​​​​Clean or replace.
Old Aug 16, 2022 | 06:30 PM
Mikew213's Avatar
Mercedes w222
Just an update, took the car to Meineke, they told me the compressor needed to be replaced and quoted me $3200, I ordered the pressure sensor and replaced myself and ac is colder than beforE… thank you guys … you saved me 3150
Old Aug 16, 2022 | 07:20 PM
FANtastic !
Everyone loves a good happy ending
This $3k discount was within your reach
Any other faulted modules while you're here?
Old Aug 16, 2022 | 07:46 PM
Mikew213's Avatar
Mercedes w222
This pesty code that’s popped up a week before the ac issue…
Old Aug 16, 2022 | 07:57 PM
is pressure regulation fail-safe ??
This fault says that your engine oil pressure regulation is faulty.
Poke around Xentry to read oil pressure data!
-- It's not bad if you're stuck always get high ressure
-- It's bad news for the camshafts spinning in aluminum heads if the valve is stuck bleeding pressure.
Old Jul 24, 2024 | 08:13 AM
Coleman Bankz's Avatar
e220 w213
pressure sensor
Hi Mike, I’m have a similar problem. Just wondering where on the car you located the low pressure sensor?
Old Jul 24, 2024 | 10:14 AM
Mikew213's Avatar
Mercedes w222
it’s under the hood right below the the center of the windshield wipers.
Old Jul 26, 2024 | 09:48 AM
Cosworth2000's Avatar
2022 E53 AMG
Good job
Old Mar 31, 2025 | 09:53 AM
lefthandclaw's Avatar
w213
Question
Shouldnt the pressure sensor be under the car in the front?
Im having the same problems and trying to make sure which sensor to order.
