E-Class (W213) 2016 - 2023
Drivers side heated arm rest not working
Old Jan 4, 2023 | 10:40 AM
JTS97Z28's Avatar
2014 AMG E63S
I have a ‘19 E63S and posted in the AMG section, but not nearly as much activity over there So figured I’d see if anyone has experienced this here.
My drivers side door panel arm rest heat does not work, however everything else does including passenger side. It’s selected on in the menus as well. I removed the door panel and visually everything looks fine, but you can’t actually see the heating element, just the wiring going to it.
My buddy hooked up his laptop and we did see a stored code that read as follows.
Thoughts?
B22F615 The output for the armrest heater has a malfunction. There is a short circuit to positive or an open circuit.
Old Jan 4, 2023 | 10:58 AM
konigstiger's Avatar
'71 Pinto
If all looks fine including wiring as you say, heating element incorporated into armrest may be malfunctioning. You were contemplating extended warranty if you purchased check to see if it is covered. Replacement armrest MSRP $325-425 depending on color, $230-300 online if you want I can pull part # to comparison shop, provide VIN.
Old Jan 4, 2023 | 12:00 PM
JTS97Z28's Avatar
2014 AMG E63S
Yes I got the extended warranty, however it almost looks like a complete door panel replacement might be required. The arm rest section is plastic welded into position as well as screws. So even if the arm rest was available on its own, it would require drilling out the plastic welded parts I guess. Not sure how they would do it to be honest. I even snapped a pic of the label on the wiring to the heat element and nothing comes up at all in a Google search for the gentherm part numbers.
VIN is WNDDZF3KB7KA545621
Old Jan 4, 2023 | 12:36 PM
'71 Pinto
Armrest is available separately, check VIN invalid.
Old Jan 4, 2023 | 12:47 PM
JTS97Z28's Avatar
2014 AMG E63S
WDDZF8KB7KA545621
sorry about that, I copied it from a sketchy screenshot. If the armrest is available separately, that would be great as it would be very difficult to find the exact spec door panel that I would need. And of course it would be a lot cheaper.
Old Jan 4, 2023 | 12:57 PM
'71 Pinto
Second capture confirms availability, comparison shop online: https://mbworld.org/forums/s-class-w...ts-online.html
File Type: pdf
Old Jan 4, 2023 | 01:40 PM
JTS97Z28's Avatar
2014 AMG E63S
awesome thank you very much for the help. I will search around and look up that part number and see what I come up with for best price thing and availability. MBonlineparts has it for $247 then whatever they add for shipping which seems pretty good so far.
Old Jan 4, 2023 | 01:51 PM
'71 Pinto
Old Jan 5, 2023 | 03:14 PM
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 18, 2023 | 04:19 PM
JTS97Z28's Avatar
2014 AMG E63S
See attachments.
Great thank you so much for all the information. I found one of the sites that has the correct arm rest for $215. That’s actually not bad for something I can replace pretty easily myself. My only concern is if that’s not the issue, but I can’t really think of anything else it could be besides a defective heating element. Everything else looked good and heated arm rest is selected on in settings. I’ve had other cars where heating elements can eventually short.
