Sudden seatbelt tightening
I have a 2020 E-350 sedan.
I had a frightening incident yesterday. I was driving along a road at about 40 mph (65 kph), in normal traffic. All of a sudden my seatbelt sharply tightened – both the driver's seat and the passenger seat. Then it relaxed. It scared us.
I have no idea why. This has never happened before. Everything seemed normal before and after the incident. I drove the car another 15 miles (25 km) and nothing further happened.
Any idea what happened?
1 Post
1961 220Sb, 1966 230 SL, 2019 E450, 2022 GLC300
There may have been a vehicle or object detected by the car that looked like an imminent collision. My car has turned on the camera system when I almost got rearended by another car. Never the seat belt tightener though...
Received 3,890 Likes
2019 C63CS
As said above, it does that if it detects a possible imminent collision. A car behind you might have approached rapidly and there was a chance that they might rear end you, or it could have been a false positive which while rare, it can happen.
I understand the principle. What about the airbag? Under what circumstances does it release the airbag? Apparently the tighten-seatbelt happens potentially more than releasing the airbag.
2019 C63CS
Received 2,616 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
As others mentioned, that is the MB's PRE-SAFE system working to help prepare you in case of an impact.
Received 4,438 Likes
'71 Pinto
The following 2 users liked this post by konigstiger:
drose224 (01-22-2023),
TennesseeZ4 (Yesterday)
The same thing happened to me and my wife the other day. No other cars or other objects nearby. Mine is at the dealer four days now with no answers. Did you ever find out the cause of your event? Mine has had numerous software updates for other faulty sensor events, in the past two years, but still does strange things (alarms, beeps, dash warnings) for no apparent reason, but this was scary for sure.
Sometimes this can be caused by a reflection. It can be perceived as a brake light. I’m a bit of a speeder so get these warnings quite a bit from brake lights and it’s happened while speeding into a reflection. Did you notice if the brakes activated at all? That’s when I would worry, if there was not real event or obvious anomolistic sensor pickup. Older new tech is definitely a bit on the rough side.
2012 E550 sedan 2019 E63 Wagon
Happened to me on my S213. And it also happened once on my W212. Multicontour seats lifted my not so ginger 300 lbs (at them time, it will probably shove me thru the pano now at 260lb) up like a gorilla lifting a baby. Was avoiding someone who was braking while getting on my lane. Seat belt tighten as well.
It is part of the Pre-Safe system, it is to prepare you for an imminent accident if the car senses that. It also does it when you do heavy braking to keep you in place, it also does it when cornering hard as well. I forgot but I think I had it do it once when I do heavy acceleration as well.
Here is an excerpt from my NTHSA complaint.
What happened?
The vehicle was in motion traveling at 35 mph and controlled by adaptive cruise control set at 35 mph. The time was 12:40 pm ET on 29 March 2019. Seemingly the car went into crash prevention mode by tightening the seat belt and executing a maximum force braking stop. The tires squealed. My chest was sore where the seat belt retracted with force. Approximate Location: Southbound on ****** near ******. ****** is a residential two lane road running North-South with dual yellow painted center marking. Road is straight and flat for approximately .2 mile in each direction. There were no other vehicles, pedestrians or animals within sight in either direction. Weather was sunny and dry with the temperature near 82°F.
When did this happen? 03/29/2019
I got our car back yesterday. The explanation was interesting. They basically just reinitialized the Distonic and related modules. The dealer said the system did not record any codes related to the reported seatbelt tightening problem!?
Here is tech's writeup - "Connected Battery Charger and SDS. Stored codes B223264, B1FBE29, B1FBF29, B1FC004, B223231, and B22347. Performed updates to the Multi-function camera. Multiple faults are current for the SCM module after update. Performed update to the SCM. SCM module update prompted initial startup of Distronic Control Unit. Performed initial startup of the Distronic Control Unit. Calibration Drive Required. Performed Calibration drive of the Distronic. 360 Cameras are no longer functioning after. Performed initial startup of the parking system control unit. Performed calibration drive of the 360 camera with SDS. Cleared faults and no faults returned. Original complaint is now repaired."
My car is still under warranty, so there was no cost to me. My understanding, after talking with the service manager was the "fix" was not specific to my reported problem, but basically a reboot and initialization of the whole system. No software updates were applied or parts replaced. How they are sure it is fixed is beyond me.
This was unlike the problem I had with the rear cameras a couple of years ago (which caused alarms and the brakes to be applied by Pre-safe system in error while backing up) when it erroneously detected something behind the car. There were software updates applied then, and I never had that problem again.
2019 C63CS
The following 2 users liked this post by superswiss:
CaliBenzDriver (08-16-2024),
Rbt1031 (08-15-2024)
Received 3,507 Likes
MY'14 W212 M276 3.5NA @60kMi
SCM firmware... only??
As I understand the issue was pinned on the Steering Module gone unreliable. Other initialization steps where incidentals triggered by SCM update.
I hope software alone will help correct hardware issues created by SCM solderless connections.
I would try to be more conservative with the DistronicPlus handling of your steering/life.
SCANNER is easy...
How about you keep an eye on this mess to get $5k jobs warranted before coverage expiration....
