Air Suspension Question
My car is at the dealer at the moment and one of the things they are doing is to exchange air suspension control unit. I have exactly same issue. Air suspension has a life on its own. Going up and down at traffic almost at all times, not to mention that it is pretty loud doing it.
Last November, one dealer told me that they have changed it however this didn’t give much. I know why now! They didn’t changed it just did reinstalled the software plus software upgrade. I know that as current dealer where my car is told me so this week. They have ordered and received a new unit two days ago. Perhaps will do some test drives today and tomorrow.
Another issue, my car has is when you drive slowly over even a small hop then you could hear, quite often, rear shock absorbers hitting the rubber top. Last dealer replaced in January, most of the bushings in the rear multi-arm suspension due to squeaking noise, it did help but not with rubber sound.
By the way, expect to get suspension warning sign soon. Had it twice already!
I am just about to file a complaint to Mercedes just waiting to see if all issues would be repaired although I will file anyway. You can read my thread https://mbworld.org/forums/e-class-w...s-already.html
Anyway I will update you once I have some news.
Heavy load on the rear axle? While driving alone with empty trunk?
The car adjusts suspension height above certain speed (lowers the car) and then raises it at lower speed. I did not check the figures for a W213 but this is just an example of suspension levelling at speed. Euro cars traditionally lower the car on Sports mode too (at speed or when stationary, when ever mode is changed). Obviously the raised mode for bad roads (low speed) can be activated and deactivated while driving.
I've had 5 different Mercedes models, a few more Airmatic cars in total and none have had any disturbing suspension levelling, at speed or when stopping at traffic lights. Have to admit that our W213 does not have Airmatic, don't think it would be significantly different from the older or the more recent models.
"When necessary" was supposed to refer to the case when the load on the car changes (people in the car or stuff at the trunk etc.) and levelling is needed to keep the set body height. Within a selected suspension mode, the nominal body height should be adjusted also if there is a leak that makes the body drop.
At high speed the target level changes within the selected mode, the mode itself does not change. If you have observed the suspension mode change on its own (the mode indicator changing too), that is not normal at all.
