E-Class (W213) 2016 - 2023
P052E issue - PCV
Old Dec 7, 2023 | 02:00 PM
ram0201's Avatar
E300
P052E issue - PCV
Recently I got this issue... dreaded one as everyone discussed.. went to the dealer. Luckily, recently Mercedes sent a letter (extended warranty) to several including me that includes the fuel intake / PCV assembly. I gave the same to the dealer and now fingers crossed if they will cover. Otherwise it will be a 2K thing in my view... I did not reset the code myself. The dealer diag fee is 327 USD that i need to pay if I take it back! Anyone with any inputs on this issue?
Old Dec 7, 2023 | 04:37 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
oil in harness... ECU $$$$
The failed PCV system needing to be replaced is one thing.
The more expensive issue right here is that failed PCV causes fatal ECU contamination with oil.
Make sure this is all repaired at once together with all evidence in place. If ECU fails 6Mo later with a dry PCV connector, then recall claim will no longer be available.
You may decide to act now by checking if ECU issue is already active.
Old Dec 7, 2023 | 05:09 PM
ram0201's Avatar
E300
PCV oil flods ECU: RIP.
good advice... i will ask them... is it easy to visually inspect?
Old Dec 7, 2023 | 06:07 PM
collateral ECU damage.
yes, you see it well in the video, it takes 5mn.
inspect PCV connector... oil?
inspect ECU connector... oil?
Use pictures as simple evidence prior to repair claim being submitted.
Of course if you had an MB scanner you'd be able to read ECU faults status easily:
  • LAUNCH
  • CARLY
  • AUTEL
Old Dec 7, 2023 | 06:09 PM
ram0201's Avatar
E300
ok.. i have given the car already to tge dealer.. did never open the hood before that.. but i am hoping they do a good job
Old Dec 7, 2023 | 06:35 PM
Yes, they have great factory trained technicians to work precisely on every single Mercedes issue.
Ask and pay if you have to get this inspection done. $300 now is worth to 10G savings. This will help you with a factual paper trail of when oil was found there....
Old Dec 7, 2023 | 11:22 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Emission controls are covered 8 years or 80,000 miles.
I believe the PCV valve/control is part of emissions controls.
I would insist this is a warranty item.
Just my $.02
Old Dec 8, 2023 | 01:21 AM
Just my $.02
i thaught this was a RECALL
Old Mar 10, 2025 | 06:36 PM
bridela25's Avatar
P052E
Guys, Im not sure they fixed exactly, what you do guys think?
