E-Class (W213) 2016 - 2023
hi air condition flap?! noise
Old Aug 26, 2024 | 04:47 AM
chansik byun's Avatar
w213 e250
Hello, I'm a person who is interested in DIY living in Korea. I've been under stress for a while trying to find the cause of the noise, but I don't have a part code or drawing, I want to see the epc wis, please help me.
Old Aug 26, 2024 | 07:48 AM
W205C43PFL's Avatar
Are you able to record the noise you are talking about?
Old Aug 27, 2024 | 07:56 AM
w213 e250
yed i have but i dont know how to update
i have mp4 video
Old Aug 27, 2024 | 07:59 AM
W205C43PFL's Avatar
i have mp4 video
You may upload to youtube or an online drive software for example dropbox then link it here.
Old Aug 27, 2024 | 02:43 PM
ua549's Avatar
Convert the mp4 to mov format online (free) then attach the mov file to your post.
Old Aug 27, 2024 | 05:50 PM
w213 e250
at last mp4 to mov converter done
Thank you all
Please listen to noise...
https://youtu.be/QKDOH0Mj_cY?si=21TBrZ9m-Xyhsqhw
Old Aug 27, 2024 | 06:08 PM
W205C43PFL's Avatar
Thank you all
Hmmm, don't see the link though.
ua549's Avatar
Thank you all
No file is attached.
Old Aug 27, 2024 | 07:59 PM
W205C43PFL's Avatar
We are now able to see your video.
I am not sure what I am supposed to be hearing, are you talking about the knocking sound near the middle of the video? As the cover is closing, I assume you had recirculation on?
Old Aug 27, 2024 | 08:45 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
NO PROBLEM...
ANIA-SAY-HO:
I was able to listen to your video post
If that's the only problem, your fine: not a problem!
A long "tic-tic-tic-tic" for 1mn would be a known problem of hard flap not initializing.
Use a good MB scanner to see AAC Module faults and actuate the 5 or 6 flaps air-con uses.
Old Aug 27, 2024 | 09:22 PM
W205C43PFL's Avatar
ANIA-SAY-HO:
That's good news, thanks forum member CaliBenzDriver for confirming to OP that it is normal and everything is all good!
Old Sep 6, 2024 | 05:11 PM
w213 e250
layout no.30 point
tic tic tic
Can you tell me the service manual? With the code
Old Sep 7, 2024 | 07:29 PM
tic tic tic
No190 is one of the flap actuator.
Use a good MB scanner to see AAC Module faults and actuate all the different air-conditioning flaps.
Old Sep 7, 2024 | 09:04 PM
w213 e250
no.190 no problem
no.30 key point tic tic tic
When the vehicle stops, it makes a plastic interference sound, so I'm going to disassemble it 30 times or attach grease or soundproof tape to the coupling part.
Old Sep 8, 2024 | 07:18 AM
managed chassis is always powered
You need a scanner to work on this system... the AAC system is always powered even with IGNITION:OFF !!
Disconnecting one of the flap actuator will cause a fault that may further disable function.
I advise you do not unplug anything with battery power active ie. consider DISCONNECTING BATT as the first step.
Without a scanner... the best choice is to let a MB specialist work on your car.
Old Sep 8, 2024 | 11:23 PM
w213 e250
last vedio thanks
After removing the blower motor this weekend, I'm going to do it with soundproof tape or Vaselinebh
and The background music is the sound of the parking lot, but would it be a copyright issue?
