E-Class (W213) 2016 - 2023
Navigation update
Old Dec 16, 2025 | 01:53 PM
Plumber452's Avatar
Navigation update
Thought I'd share something I recently learned about my 2018 E 400. I just recently purchased the car and couldn't get the navigation system to work. I kept getting a message to insert map media. After much internet searching I learned that this car with code 531 got it's update over the air or via a USB flash drive after having downloaded the update off the MB app. I registered my car, which had never been registered on the app, and attempted to download the updates. I got a message that my car was unable to do that and was given a 800 number which I called. They were helpful but said I needed to contact a dealer. After speaking to the service department which referred me to sales I've learned I'm basically SOL...... The salesman was quit helpful and said that basically anything prior to 2022 that used over the air or USB updates was obsolete and not worth trying to use. he recommended using Apple Car Play or Android Auto. Which I've used the Android and it worked fine. He said he didn't think Mercedes ever had as good of maps as Google. LOL!! And, he says he try's to talk customers out of subscribing to the $17.00/month fee to use the features on the app.
So, I hope this helps someone chasing this issue like I have. So far the car has been a blast to drive.
Old Dec 16, 2025 | 02:26 PM
trigital's Avatar
W213 All-terrain
Maybe the salesman was frustrated or receives a job offer from BMW
Mercedes Maps are quite nice and very helpful because is offline. If you pay for Live Traffic subscription is even smarter.
More of that...is free for most of the members here.
If your car had 531 Option code - Comand NTG5.5, check my posts and if you manage to download the latest Map - for US the V30 just arrived - I will give you the activation code for free
Old Dec 16, 2025 | 03:29 PM
Plumber452's Avatar
Wow!!!! thanks!! I'll check right now. I know I have the 531. I did a VIN decode and see it. Thanks!!!
Old Dec 16, 2025 | 04:02 PM
ua549's Avatar
@trigital
Is there a link to download the navigation map V30?
Old Dec 16, 2025 | 04:17 PM
Plumber452's Avatar
So, I found the MB downloader at a website MBRetrofit, downloaded it, found my NTG5.5, United States, a spare USB Drive and I'm currently downloading the maps. I understand this can take some time. The only reason I've gotten this "New" car is I was rear ended recently in my E63 AMG and it was totaled. So, i'm looking forward to unlocking and enjoying this "New" car.
Old Dec 16, 2025 | 04:32 PM
trigital's Avatar
W213 All-terrain
After the USB will be ready, insert into car USB panel to check if everything is OK. If your Head Unit will ask for the Map Activation Code you will have to post here:
VIN
Map Version
Region
Old Dec 16, 2025 | 06:10 PM
Plumber452's Avatar
Great news!!! it woke the system up!!!! It's asking for an activation key. My info is:
VIN: WDD1J6FB4JF019393
Map version: 30
Region: North America
Old Dec 16, 2025 | 06:29 PM
trigital's Avatar
W213 All-terrain
Map version: 30
You need to know that if your car has never been updated with maps or the current version is too old, some errors can occur
Old Dec 16, 2025 | 07:12 PM
Plumber452's Avatar
So, what is the activation code/ the one in the screen shot?
Old Dec 17, 2025 | 10:26 AM
trigital's Avatar
W213 All-terrain
Yes, it is the "Generated Code"
Old Dec 17, 2025 | 11:06 AM
Plumber452's Avatar
GREAT!!! It started installing. I didn't start the car I just pushed the ignition button once. After I got my battery charger out and hooked up when I pressed the ignition button once and went to the Navigation I got the message insert media. I didn't remove the USB drive and I see the red light on the USB flickering.
So, do I not touch anything or am I going to have to drive around until it finishes installing?
Old Dec 17, 2025 | 01:01 PM
Plumber452's Avatar
So, it finished installing said the system needed to be restarted and I did. Everything seems to be working GREAT!!!!!
Thanks so much!!!!
Old Dec 31, 2025 | 08:22 AM
jimmag's Avatar
Trigital or Plumber 452,
I have a 2017 GLE 350. The head unit, Radio and Navigation system, went black. I had to replace it with a used one. Wasn't easy to get the whole thing up and running. Had to take it to the dealership and paid $250 to clear the anti-theft code, but then it worked. Problem is there is no Navigation installed. I get a message that says install media. Bought one on Amazon but it was not compatible. After a little research, I believe I have the COMAND NTG5.1 system. Apparently not compatible with most SD Cards. I am trying to find Navigation updates North America edition for this vehicle. I should have had the dealership install it, but the are notoriously overpriced on everything.
Would either of you be able to help?
Thanks,
Jim
Old Jan 3, 2026 | 11:45 AM
trigital's Avatar
W213 All-terrain
First you have to tell us if you have Comand or Audio 20.
Only Audio 20 accept Maps over Sdcard.
Command has HDD and the Maps can be installed from a USB
Old Jan 3, 2026 | 01:59 PM
Plumber452's Avatar
Follow Trigital's instructions. He really helped me out. Can you go to settings and see what system you have? I apologize for not being much help. As you can tell if you've read though this thread the "Steaership" I mean dealership may not always be that helpful.
Old Jan 4, 2026 | 12:19 PM
jimmag's Avatar
Navigation update
Yes. It is definitely a COMAND head unit. NTG5.1. Thanks
jim
Old Jan 6, 2026 | 02:54 PM
jimmag's Avatar
This is definitely a COMAND unit NTG5.1
Old Jan 6, 2026 | 02:56 PM
jimmag's Avatar
Thank you Plumber452. I'm hoping Trigital can, and will follow those instructions...Thank for letting me jump in on your thread
Old Jan 6, 2026 | 02:57 PM
jimmag's Avatar
Definitely a COMAND NTG5.1
Old Jan 8, 2026 | 11:25 AM
jimmag's Avatar
Trigital,
I have tried to reply to this thread several times. New to the forum so sorry for the delay.
Yes...This is a COMAND Unit NTG5.1.
Old Jan 8, 2026 | 11:26 AM
jimmag's Avatar
COMAMD NTG 5.1
Old Jan 9, 2026 | 03:41 AM
spacemaster's Avatar
W213 2017 E400
Yeah... I just bought W213 2016. Maybe my car is old and Mercedes portal does not allow my car update and can't even see the download Manager. In fact, in the last few days I could not find Mercedes DL Manager anywhere until I see this thread and went to MBTools as Plumber452 said.
I do exactly what Plumber452 and follow Trigital's instruction.
@trigital just wondering if you can help me with the code please.
VIN: WDD2130662A189071
Nav System: NTG 5.5
Map Region: Australia/New Zealand
Version: 2025 (V12)
Very much appreciate!
Old Jan 9, 2026 | 04:37 AM
trigital's Avatar
W213 All-terrain
Nav System: NTG 5.5
Version: 2025 (V12)
Did you successfully wrote the USB? What's the message from screen when you insert the USB?
If all OK try this Generated Code ...and do not forget to do the 143 days delayed maintenance to your car as the till now the service history was perfect.
Old Jan 9, 2026 | 06:16 AM
W213 2017 E400
Thanks heaps @trigital
I completed format and download the map into both usb and SD card (as my car have both interface inside the hand rest storage).
It is very dark in Australia now, so I probably will try to insert the SD Card into the car tomorrow morning. I will report back here my progress.
BTW, you mean I have to wait for another few months before I performing service to the car ?
Old Jan 9, 2026 | 06:28 AM
trigital's Avatar
W213 All-terrain
Delayed means is already due with 145 days. I would prioritize the maintenance if you want to keep a clean record.
