E-Class (W214) 2024 -
Charging the E53 battery
Old Apr 16, 2025 | 09:44 PM
Rick_H's Avatar
2025 E53
I had a random thought. When I picked up my car, while the dealer was going through all the bells and whistles, I remember him saying that the battery doesn’t like to be run below 20%
Was anyone else told that? Is it a thing? I guess I should have asked him why, but we just kept moving.
Old Apr 16, 2025 | 11:21 PM
Arjy's Avatar
2020 E63s Wagon, 2012 C63 AMG Coupe, 1989 560SL, 2023 911 Carrera T
Not sure about the E53 specifically, but in general it is recommended to keep lithium batteries like those used in EVs and hybrids as well as your phone between 20-80% charge to prolong the life of the battery. I assume they were referring to that.
Old Apr 17, 2025 | 07:50 AM
W205C43PFL's Avatar
Yes, likely. I also heard from a site called Battery University is if it is charged like that, it doesn't count as 1 full charge cycle of the battery.
Old Apr 17, 2025 | 11:59 AM
Steven H-R's Avatar
2025 E53 AMG
Per the online manual it’s 15%.
Old Apr 17, 2025 | 12:08 PM
W205C43PFL's Avatar
15% it is
Old Apr 18, 2025 | 07:50 PM
SamWeb's Avatar
MB E53
What about if the battery goes down to 25-30%, for example? Should we wait until it reaches 20% to charge it? Or is it OK to charge it from a higher level than 20%?
Old Apr 18, 2025 | 09:05 PM
LAZARU5's Avatar
2025 E53 Hybrid
If you drive the car every day, I would charge it to 100% every night. The battery capacity is so small that if you don't leave your home at 100% SoC then you will be driving around at 0% SoC before you know it.
Old Apr 21, 2025 | 01:32 PM
petee1997's Avatar
...24 GLE53
I thought you could plug the in 110 wall plug to charge because the car has a built in charger.
Old Apr 21, 2025 | 01:34 PM
petee1997's Avatar
...24 GLE53
I am in the process of making a decision if this is the right car for me. the weight and ride are my main stumbling blocks.
Old Apr 21, 2025 | 02:04 PM
W205C43PFL's Avatar
Adjusting the tire pressures help with the ride.
Old Apr 21, 2025 | 04:28 PM
LAZARU5's Avatar
2025 E53 Hybrid
Technically the charger is built into the car. But, you need an EVSE to attach the car port to a power source at your home. MB supplies a portable EVSE, with the car that has plugs for 240v and 110v power. If you choose to use the 110v cord, it will take close to 24 hours to charge the car from 0% SoC to 100% SoC. If you don't have a very long commute, you may get by with charging with 110 volts.
