E-Class (W214) 2024 -
E53 tire pressure
Old Jun 2, 2025 | 09:45 AM
Rick_H's Avatar
2025 E53
E53 tire pressure
I was getting a "front" tire pressure warning last week and I spent some time over the weekend and failed to get rid of it. The warning says to refer to the recommended psi inside the gas cap. I have 21" wheels and the tires recommend 40psi. The sticker inside the door says 44psi. The sticker inside the gas cap says 39-44psi. Over the weekend I adjusted the psi anywhere from 36-44psi and am still getting the warning light. If I remember correctly, I think the original psi was around 44 before I got the warning light, but not totally sure. Which makes me think, why would I want to run 44psi when the tire says 40psi? Any recommendations, or anyone running 21" wheels can you tell me what your current tire pressure is for you fronts tires? Thanks!
Old Jun 2, 2025 | 09:54 AM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
The PSI on the gas flap is for cold tire pressure and should be used. This has been discussed in numerous threads. After adjusting the tire pressure as per the cap, reset the tire pressure. Your warning light should then go out.
Hope this helps.
Old Jun 2, 2025 | 10:17 AM
regor60's Avatar
06 E55 Black
Nevermind
Old Jun 2, 2025 | 10:30 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
You go by the fuel tank sticker...and from there, assuming you are not on Run Flats (ditch em if you are :-) ....I go to the high end to protect my rims.
Old Jun 2, 2025 | 10:33 AM
JTK44's Avatar
The pressure for non RF and RF are the same.
Old Jun 2, 2025 | 11:00 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
To add to what has already been said, the tires do not have a "recommended" tire pressure on them. At least I've never seen one that does. What is on the physical tires is the max pressure. If the gas tank flap is saying a higher pressure than the max pressure of the actual tire something is wrong. Are you saying that the tires themselves have a max pressure of 40psi? Seems pretty low for a max psi of a tire.
Old Jun 2, 2025 | 11:10 AM
JTK44's Avatar
You are correct: there is only a max pressure on the tire, not a recommended pressure.
The same tire can often be found on different vehicles so a "recommended" pressure is not possible, as each manufacturer determines the ideal tire pressure for their cars.
I have never seen a situation where the recommended pressure as found on the gas flap, exceeds the maximum pressure on the tire.
Old Jun 2, 2025 | 11:23 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
I haven't either. If it does, then it is likely that the wrong tires are on the car. I doubt that is the case for the OP. They likely just read something wrong.
Old Jun 2, 2025 | 12:25 PM
And, no matter what...remove the RF, while not a "true" AMG...it deserves a real tire
Old Jun 2, 2025 | 12:30 PM
Rick_H's Avatar
2025 E53
I have the Michelin Pilot Sport 4S and the tire says 40psi...that's why I am confused. Why would the gas cap say up to 44psi when the tire says 40?
Old Jun 2, 2025 | 12:34 PM
The tire has no idea what car it is going on, what that car weighs and on and on and on...never, not ever go on what the tire says. Not even on a bicycle.
Old Jun 2, 2025 | 12:39 PM
JTK44's Avatar
Contra point: the RF gives valuable safety that non RF do not have: The chance of a catastrophic failure with non RF vs. RF is so much higher, to gain marginal handling with non RF and give up the safety of the RF makes no sense.
If you hit a pot hole, a non RF with blow: a RF will have a tire bulge.
At night if you have a blowout, with a non RF you are stranded: either you carry a spare and give up the trunk or wait for a tow truck: with a RF you continue on your journey.
Just my $.02.
Old Jun 2, 2025 | 12:44 PM
JTK44's Avatar
Thanks.
Confirms posts #6 and #7 above.
Old Jun 2, 2025 | 02:03 PM
ua549's Avatar
Just my $.02.
Did you pull that catastrophic failure statistic from thin air or elsewhere? I've had two, non-repairable (catastrophic) failures with RF tires and never had a non-repairable failure with a non-RF tire.
If you have a blowout with a RF tire, you are stranded because they are not drivable. I had that experience and it reinforced my decision to switch the non-RF tires. The handling and ride is noticeably better with non-RF tires due to the elimination of about 20 pounds of unsprung weight and a more flexible tire.
Old Jun 2, 2025 | 02:12 PM
JTK44's Avatar
No the weight difference is not 20 lbs. but less than 3 lbs per tire.
No actually personal experience:
I was changing a tire. On the inside there was a huge bubble. I had driven on it several hundred miles without knowing the bubble was there. If this was a non RF without the reinforced sidewalls I would have suffered a blowout.
Common sense dictates this result: RF have reinforced sidewalls vs. non reinforced sidewalls on a non run flat. That reinforced sidewall makes the tire safer.
Hope this clarifies.
Old Jun 2, 2025 | 05:06 PM
ua549's Avatar
You are jumping to a conclusion that reinforced sidewalls equates to some undefined aspect of safety. One could also posit that rough/hard handling vehicles are less safe than smooth handling vehicles.
The weight difference depends on brand and size. For my E300 size 245/45-18 the difference is 24 pounds per set of 4.
Continental ContiProContact SSR (RF) = 30 pounds
Continental ProContact TX (non-RF) = 24 pounds
Specs from Tire Rack
Old Jun 2, 2025 | 07:19 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
Can you provide a picture of the tire saying 40psi?
Old Jun 2, 2025 | 07:21 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I know its hard, but can we try and stay on topic. The OP is asking about tire pressure. We don't need a back and forth on RF vs non-RF tires.
Old Jun 2, 2025 | 07:57 PM
JTK44's Avatar
Just went to Tirerack.com to look up the maximum pressure for the Michelin Pilot 4S, 21 inches which I assume the OP has on his car.
The max pressure, according to Tirerack.com is 51 psi.
Mystery solved, I hope!
See: https://www.tirerack.com/tires/tires...20295%2F30-21R
