E55 AMG W211 Vendor Classifieds Forum Specific Vendor classifieds - Test sub-forum
Smaller Supercharger Pulleys for M113K
Old Sep 5, 2012 | 04:01 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I have another batch of smaller supercharger pulleys ready for shipment.
84mm in size
1.5 to 2 psi increase (as compared to a stock supercharger pulley)
2.5lbs (one pound less than stock 3.5) ~28.5% reduction in weight
equates to 168-170mm crank pulley in power
requires the ECU to be tuned due to differences in AFR (a lot of tuners have tuned cars with this product)
comes with oem nachi bearing.
Price is 625 shipped in the continental US. My paypal is mehtashardul@hotmail.com
Kauve's car ran a 11.7 with this pulley, heat exchanger and tune on 18" BFG DRs mounted on stock E55 rims.
Here is a video
Old Sep 5, 2012 | 04:29 PM
GunMoto's Avatar
EG8 | E46 | W211
I think this will eventually be my first performance mod.
Old Sep 5, 2012 | 05:07 PM
Toadster's Avatar
2005 E55 AMG
+1 for a great mod
Old Sep 12, 2012 | 11:43 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Originally Posted by Toadster
+1 for a great mod
My engine revs way quicker now with the SC pulley mod , did you notice the revs? Taking the extra weigth off the SC rotors X 16000 RPM and combined with more boost is the ticket.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 15, 2012 | 06:56 AM
Brave7012's Avatar
E55
What is the difference between this and swapping to a larger pulley. While the net boost comes out to the same, any benefits with using this over larger pulley to raise boost?
Old Sep 15, 2012 | 07:59 AM
shardul's Avatar
Some people don't like to swap out the crank pulley.
Old Sep 15, 2012 | 06:53 PM
Koru_Kinshi's Avatar
2018 E63S AMG, 2003 SLK 230 Sport, 2004 SL 600, 2006 SLK 55 AMG, 1998 E320 Wagon
Difference between this and the Eurocharged SC pulley?
Old Sep 16, 2012 | 12:21 AM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Nothing
Old Sep 23, 2012 | 01:17 PM
PLATINUM SPONSOR
2003 CL55
Price is much better, install is way easier and you take a huge amount of rotating mass off your supercharger with the 83mm Sc pulley that is about 33% lighter. Most crank pulley`s add weight , when they go to a larger outer ring. Some as much as 40%.
__________________
www.ultimatepd.com
Old Sep 25, 2012 | 06:41 PM
99lightning's Avatar
99 ford lightning
I bet even in stock pulley size that product would make a hp difference due to being light weight.
Old Sep 26, 2012 | 09:34 AM
Brave7012's Avatar
E55
Say in an event a supercharger pulley fails, what will be the common modes of failure and what damage is it likely to create in comparison to the extent of damage from a larger crank pulley ?
Old Sep 26, 2012 | 09:45 AM
Hulk's Avatar
A Merc
Clutch will stop working, if the crank pulley fails it could damage the key way, snout and or crank...alot more damage and very expensive to fix
Old Sep 26, 2012 | 10:00 AM
shardul's Avatar
Stock pulley 3.6 lbs plus.
Smaller pulley 2.3lbs
Old Sep 26, 2012 | 05:52 PM
AKnight55's Avatar
I just ordered one through EC.. Will I need a new SC belt? I have a stock crank pulley. I havent changed my belt for a few years, so think it might be a good time anyway.
Old Sep 26, 2012 | 06:00 PM
kustom2k1's Avatar
03SL55
Gained 20HP and close to 40TQ adding this pulley to a 168 on the crank and that was in 95 degree weather. Install took about 15 minutes with lift access.
Old Sep 26, 2012 | 06:22 PM
AKnight55's Avatar
Thats a pretty good gain
Old Sep 26, 2012 | 07:45 PM
berti_00's Avatar
2016 Cls63s AMG
i just installed mine i have some rattles but i will drive it a week or so to see if it goes away... anyways i didnt get to hit the gas as i need a re-tune for it so i took it easy kept it under 3k rpm
Old Sep 26, 2012 | 07:49 PM
Hulk's Avatar
A Merc
Bro you really don't have to baby it and keep it below 3k, you can actually see when sneakyneon did a bunch of mods with a bigger pulley and actually went to the track that way, just drive normally , don't worry
Btw how many shims did you add since you have a noise, you can add more shims possibly
Old Sep 26, 2012 | 08:07 PM
berti_00's Avatar
2016 Cls63s AMG
we added enough shims to make it .55mm clearance so i'd say 3 or 4
noise has been kinda going away as i was driving so i'll drive it like this for a week or two and than see if its still there
Old Sep 26, 2012 | 08:14 PM
Hulk's Avatar
A Merc
Drive for a few days and see or else add more shims, some SC pulleys have needed more
Old Oct 9, 2012 | 08:00 PM
Driftvs's Avatar
03 E55, HB Torana
Has anyone installed a smaller s/c pulley with a 180mm crank pulley?
What sort of results would be expected?
Old Oct 9, 2012 | 08:50 PM
shardul's Avatar
There are a few poeple. The boost generated will be equal to a 190mm
Old Oct 9, 2012 | 09:28 PM
Driftvs's Avatar
03 E55, HB Torana
So with the equivilent of a 190mm pulley, cooling would be pretty important.
I have an upgraded EC heat exchanger and upgraded IC pump, is that enough? Or would I need to upgrade the cooling system further?
Shardul, what would you recomend?
Cheers
Old Oct 10, 2012 | 10:06 AM
shardul's Avatar
Cheers
PM sent mate
Old Nov 7, 2012 | 09:36 PM
PLATINUM SPONSOR
2003 CL55
Cheers
Headers also help a lot with cooling and power.. Nice set up you are building.
__________________
www.ultimatepd.com
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
