FS: ASP Custom lightweight 185 mm kit
PLATINUM SPONSOR
This is used kit but comes with, 185mm pulley, aluminum WP pulley and new belt. This was on my car and was special made to keep rotating mass down.
The outer ring is machined of aluminum and maintains near stock rotating mass. Many of the larger pulley can increase rotating mass by 30-40%!!This also comes with a lightweight aluminum water pump pulley that is designed to maintain stock flow rates. Pulley is in perfect condition and runs perfectly true! I will miss the custom kit but had to go larger! This custom kit cost 1200.00 new and I am selling it for only 600.00 with new belt. I am including TWO belts, one is a new gates gator grip and theother a slightly used gates belt.
Pulley is painted flat black but outer ring is lightweight aluminum and the WP pulley is also the best made!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
Yes, planned to put pics but pulley is at my office right now.
Yes, it is a stock AMG pulley and was custom made with aluminum outer ring. I am big on keeping weight down on my phat CL. This is a great pulley and is perfectly straight and balanced.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Yes, I saw a solid .5 plus over my 180mm. Part throttle improved a lot too.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
SOLD
__________________
www.ultimatepd.com
www.ultimatepd.com
