EQS SUV Forum for Discussion of EQS SUV
How To Keep The EQS Running With No One In The Driver’s Seat?
Old Jun 15, 2023 | 04:58 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
I know I am missing something obvious and need some help here. This is on a 2023 580 SUV. My wife and I were out today and needed to stop at the pharmacy to pick up a prescription. It was 101F in the parking lot and with her health it takes forever to get her in and out of a vehicle so I thought it best to leave it running with the AC on and go into the pharmacy quickly. I even left the key in the vehicle and my wife said it stopped in about two minutes. How can you keep a EQS running with the AC on without someone in the driver seat for a longer period? Help appreciated. 😊
P.S.- Told my wife about Tesla’s Dog Mode and she gave me a dirty look…
Old Jun 15, 2023 | 05:25 PM
wildta's Avatar
GLE 580
Try putting it in neutral with the parking brake on.
Old Jun 15, 2023 | 07:59 PM
thebigkat82's Avatar
EQS
I've turned the vehicle "off" and then ran preconditioning mode on the app
Old Jun 15, 2023 | 08:06 PM
wildta's Avatar
GLE 580
That would be the safer method.
Old Jun 15, 2023 | 08:22 PM
Is that the way also to run the AC during hot weather when charging at a DC charger while on the road? Reason I ask is up until now have only charged at home
Old Jun 15, 2023 | 08:29 PM
EQS
I have had no issues charging and running climate control
Old Jun 15, 2023 | 09:10 PM
Ok, Thanks!
Old Jun 16, 2023 | 04:17 AM
finlayson's Avatar
No Mercedes yet
You don't need to use the app. Instead, turn the vehicle off, but before opening the door to exit it), press the 'fan/ventilation' icon that's at the bottom left of the center display (next to the climate control). That will keep the climate control on for up to 30 minutes or so, while you leave the vehicle.
Old Jun 16, 2023 | 05:59 AM
EQS
thanks for that, I will try it here soon
Old Jun 17, 2023 | 07:35 AM
EQS
perfect
thanks
Old Jun 17, 2023 | 10:21 AM
W205C43PFL's Avatar
Problem is, isn't there a requirement to have the doors locked I guess with the key and therefore alarm is activated same goes with motion sensor?
Old Jun 28, 2023 | 07:40 PM
TTOWN ROCK's Avatar
2023 EQS 450+
I found this solution somewhere and it works. Put the gear shift in Neutral, Press the Emergency Brake, then fasten seat belt.
Old Jun 28, 2023 | 07:56 PM
W205C43PFL's Avatar
but is it safe?
Old Jun 28, 2023 | 08:05 PM
Never mind….
Old Jun 28, 2023 | 09:35 PM
TTOWN ROCK's Avatar
2023 EQS 450+
YES...
Old Jun 28, 2023 | 10:00 PM
W205C43PFL's Avatar
YES...
Good.
Old Jul 19, 2023 | 07:49 PM
LAZARU5's Avatar
2025 E53 Hybrid
Thank you for pointing out this feature. I tried it yesterday and it worked as you described when I left my wife in the SUV while I went into a store for ten minutes. I would like to point out that it is necessary to set the temperature before enabling the feature and leaving your car since the passenger left behind will not be able to adjust the temperature level.
Old Jul 19, 2023 | 11:41 PM
guess2098's Avatar
2022 Taycan GTS, 2023 EQS580 SUV, 2023 EQS580 sedan
I might be wrong but if I remember correctly, just open the door, screen will come back and you should able to adjust it (without key)
Old Jul 21, 2023 | 09:39 AM
TTOWN ROCK's Avatar
2023 EQS 450+
I did a 2 hour trial run on the solution that I posted earlier and it works, (1) Push gear shift up or down to "N", (2) Press "Electric Park" located on lower left . A red "park" will appear in Driver"s Display,(3) Fasten seat belt and close door. Try it You'll like it....
Old Jul 21, 2023 | 09:41 AM
TTOWN ROCK's Avatar
2023 EQS 450+
CORRECTION-- Push gear shift to "N" ....
Old Aug 3, 2023 | 06:50 PM
TTOWN ROCK's Avatar
2023 EQS 450+
Did my solution work for anyone???
Old Aug 3, 2023 | 08:16 PM
Tjdehya's Avatar
2023 AMG EQS
I did this when I first got my EQS an over a year and a half ago. There was no need to fasten seatbelt.
I haven’t done it since but maybe there was a software update. Why do you need to fasten seatbelt?
Old Aug 3, 2023 | 08:45 PM
TTOWN ROCK's Avatar
2023 EQS 450+
I don't know why. This was solution I found. It worked and I didn't try without seatbelt fastened.
