Headlights and corner illumination
2. I think it does have the corner illumination built-in but it's disabled in the US market. I think (?) if you code the lights to have the matrix functionality enabled, this might also enable the corner illumination feature.
I used to have a Obdeleven for my q7 that allowed me to change some settings via obd, vag like AC output adjustments so on. I am guessing this coding isn't something I can do myself in this case though?
My Audi before had a seperate light (or something) that lit on the side you signaled while turning like that which was really helpful on corners. Our cx5 lights also turn regardless of motion which helps a bit to lit up corners.
Anyway, not much I can do I guess.
I do NOT have any cornering lights. Neither moving nor standing still.
They do move however when steering wheel moves (to see around bends in road? - Is this what they are calling cornering lights. I think of 90 degree lights t the side.)
I have only seen two of the digital projections (Lane change and Lane departure). There are supposedly several more like construction warning and pedestrian spot?
When I mentioned this to the dealer, he said that some of these projections will only occur if it's very dark out and there are no street lights around. Could be, but I haven't been in these conditions yet. We shall see, eventually...
EDIT: Had to run out for bottled water so here ya go. I've had my HUD on since day I bought the car.
https://www.youtube.com/shorts/G7VuEpbL7EY
