EQS Problems
I’m with you. I have a 23 model and was hoping the bugs for the most part have been worked out. I have been getting this message lately, and most of the time it was during the rain. I got it today and the weather was fine. I had the car in the shop the other day for a minor issue and showed them this message. Their reply was no faults codes popped up and it most likely a temporary sensor issue. It goes away after I shut car off. Was told that since it says limited it will correct itself and I don’t have to bring it in for service. Any thoughts on that?
Its funny that the message says "See operators Manual" but when you look it doesn't mention the fact that the likely reason you are getting those messages is because your tire pressure is low.
Put some air in your tires and the messages should go away. If they don't then you may in fact have a problem.
I can already tell that is why Fyrcity has those messages based on the first picture that was posted. Good luck
And yes, manual didn’t help me out with the warning.
