EQS EQS (V297) sedan
Default to rear climate off?
Old May 9, 2023 | 02:04 PM
KieranT's Avatar
Tesla Model Y
I have a 2023 450 4Matic sedan with 4 zone climate control.
Is there a way to have the car default to having the rear climate off? Right now I have to physically reach back into the backseat with my arm and turn off the rear climate every time I start the car.
Old May 10, 2023 | 06:52 AM
jlt1112's Avatar
EQS 580
I am not sure if you can permanently shutoff the rear A/C as I leave mine on. You can control it from the central screen. Selected the "menu" button in the climate control section (lower part). You will get a screen that allows you to select airflow etc. Just above is a tabbed section that lists "front", "rear" and air filtration stuff. Selection "rear" and then use the fan controller to turn off the unit.
Old May 10, 2023 | 10:52 AM
Tjdehya's Avatar
2023 AMG EQS
Why do you want to turn off. You do realize that it doesn’t matter if it’s on or off right? You are not saving any energy by turning them off if that’s what you are concerned about.
Old May 10, 2023 | 10:58 AM
KieranT's Avatar
Tesla Model Y
Really? I was assuming heating and cooling the rear seats used more energy, is that not how HVAC works on the EQS?
Old May 10, 2023 | 12:42 PM
bgrewal's Avatar
EQS580
Heat follows cold. If the air in the back is cold then all of your hot air from the front will go to back and the car will continually try to keep heating the front until the entire car temp is at your desired level.
Old May 10, 2023 | 01:15 PM
nosnoop's Avatar
535
Maybe the case of single zone climate control, but I don't think that's how it works for 4-Zone climate control.
Old May 10, 2023 | 01:27 PM
Tjdehya's Avatar
2023 AMG EQS
in any confined space you have to heat/cool the entire space. The only way to save energy by turning off the rear climate control is to put up partitions.
Yes, it will always be warmer/cooler the closer you are to the source but if you don’t confine the air, the warmer air will move to cooler air and vice versa, the source will just have to work harder to keep the desired temp. Even if you are the only one in your car, you still have bring the entire cabin up to your desired temp. So it’s either have the front and back to bring the car to the desired temp or have only the front bring the entire car to the desired temp… same amount of energy.
There will always be temperature loss based on the delta between the outside temp and the desired cabin temp so to save energy you could have the unoccupied area one or two degrees closer to the outside temp because there is no point in trying to make up for the delta loss. But you won’t save any energy worthy of concern by having the climate control off.
Old May 10, 2023 | 01:34 PM
Tjdehya's Avatar
2023 AMG EQS
unfortunately that’s how life/science works. If you want to get nerdy about the subject then look up thermodynamics. I took a class on it decades ago but googling the simple basics of it should help anyone understand how this complicated simplicity works.
Old May 10, 2023 | 06:30 PM
nosnoop's Avatar
535
This is exactly what I am referring to.
4 Zone climate control has 4 zone vents and 4 temperature sensors, one in each corner.
Assuming having one vent on uses less energy than using 4 vents, then if you just turn on one vent in one corner, and only have temperature sensor in that corner active (effectively what you are trying to do when you turn the climate control of the other unoccupied areas off), you would be able to ignore temperature loss in the other 3 corners, and should use less energy than turning on 4 vents.
Old May 10, 2023 | 08:14 PM
AppleFan1's Avatar
2025 EQS580
That’s exactly correct. I’m a retired meteorologist and that’s one of the laws of physics.
