Has anyone here lifted their G class?
Old Nov 4, 2019 | 11:37 AM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
Looks great. How did you mount the fox shocks 2.0 reservoirs horizontally like that? I just saw that you are located in Houston as well. Who did the installation for you?
Old Nov 5, 2019 | 09:33 AM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
they come with the brackets from viking to fit in that way - although I think one had to be modified a bit on my G63. really liking the Fox's over the OEM shocks....
We should do a G meet ..
Old Nov 5, 2019 | 02:26 PM
HtownG's Avatar
2014 G63, 2018 LC500
The shocks come with brackets to mount horizontal but need to do minor modification. Installers at 4 wheel parts on Westheimer cut out little piece of plastic liner.
Old Nov 5, 2019 | 02:27 PM
HtownG's Avatar
Great idea for G meet
Yes! We should.
Old Nov 5, 2019 | 03:29 PM
horse86's Avatar
Range Rover, M5
HtownG.....how hard was it to install those LED signals on the fender? Heard they are a PITA to fit and wire up so they don't hyper-flash
Old Nov 5, 2019 | 03:40 PM
HtownG's Avatar
They were easy to install. Each one came with resistors so no flashing error.
Old Nov 5, 2019 | 03:48 PM
  #32
horse86's Avatar
Range Rover, M5
Do you have a link for the ones you bought? Every other person I’ve seen comment said they needed to hack them up to fit properly.
Old Nov 5, 2019 | 04:11 PM
  #33
HtownG's Avatar
https://www.amazon.com/iJDMTOY-2002-14-Mercedes-G-Class-Sidemarker/dp/B07F6SY9XK/ref=mp_s_a_1_34?keywords=g63&qid=1572988161&sr=8-34 https://www.amazon.com/iJDMTOY-2002-14-Mercedes-G-Class-Sidemarker/dp/B07F6SY9XK/ref=mp_s_a_1_34?keywords=g63&qid=1572988161&sr=8-34
Old Nov 5, 2019 | 04:18 PM
  #34
horse86's Avatar
Range Rover, M5
That links for side markers not the turn signals
Old Nov 5, 2019 | 05:20 PM
  #35
HtownG's Avatar
This one?
https://www.amazon.com/iJDMTOY-LED-Turn-Signal-Mercedes/dp/B06XGMJN5Y/ref=mp_s_a_1_20?keywords=g63&qid=1572992389&sr=8-20 https://www.amazon.com/iJDMTOY-LED-Turn-Signal-Mercedes/dp/B06XGMJN5Y/ref=mp_s_a_1_20?keywords=g63&qid=1572992389&sr=8-20
Old Nov 5, 2019 | 07:10 PM
  #36
invictusmaneo's Avatar
Lifted G500, GT-S, track Cooper S
FWIW, the OEM G63 side markers are not that expensive and only need a resistor wired in. I went that route.
I am running Kings and they ride MUCH better than stock. That being said my extra few inches of lift have changed the geometry in other ways, but the ride itself is amazing, and I get a lot of compliments from folks who ride in it. I would imagine Fox / King are both an upgrade over stock.
Old Nov 5, 2019 | 07:19 PM
  #37
Texas E63's Avatar
your truck was one of my inspirations..... it still needs my old light Cannons.... although I cannot figure out a good mounting option for them nor my LP6's that I bought for it....
a houston meeting around coffee or beers, or even a cars & coffee looks in order...
E
Old Nov 5, 2019 | 11:08 PM
  #38
cwwheels1's Avatar
G500 and GL450
Just finished G class lift with Thor springs, Fox shocks, and 35s
Old Nov 6, 2019 | 06:00 AM
  #39
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, GLE AMG 63S
WOW !!!! I bet this rig gets attention.
Old Nov 6, 2019 | 07:01 AM
  #40
horse86's Avatar
Range Rover, M5
that a fire truck or gwagon? lol damn thats bright!
I like it minus the wheels
Old Nov 6, 2019 | 02:25 PM
  #41
DD0220's Avatar
2020 G63
Originally Posted by cwwheels1
Not my cup of tea
Old Nov 6, 2019 | 07:52 PM
  #42
cwwheels1's Avatar
G500 and GL450
Breaks my heart
Old Nov 7, 2019 | 01:24 PM
  #43
mrtonyn's Avatar
1999 E320, 2008 S550, 2016 G63 AMG
Low profile tires on a 4x4 never made sense for me...
Old Nov 7, 2019 | 01:57 PM
  #44
Texas E63's Avatar
agreed - I wanted 18" rims but they only left 2mm of clearance on the barrels to the caliper.... roads must be better there than Houston and assume it'll stay on the street.
@cwwheels1 was the Brabus tune and DP's added as part of your build ?
Old Nov 7, 2019 | 02:56 PM
  #45
cwwheels1's Avatar
G500 and GL450
Texas.....it’s definitely a showpiece (mall crawler). 37s are coming soon. The sidewall that is on all G class from the factory is the same that’s on mine now. Unsure about the tune as the work was already done when I purchased it.
Old Nov 7, 2019 | 03:33 PM
  #46
horse86's Avatar
Range Rover, M5
just noticed the mirrors....so thats an older gen then. Still in very nice shape
Old Nov 13, 2019 | 11:42 AM
  #47
nlakind's Avatar
@HtownG
Love this, did you do the Fox shock with the THOR springs from Viking? Thinking I'm going same route. Looks like you can get up tp 2.75" lift out of the front with this set-up, any reason you didn't go the extra distance? And did you do extended brake lines?
Originally Posted by HtownG
Hi new to the board. Installed 2” lift with springs and shocks on 35” Toyo tires. Trouble free so far.
Old Nov 13, 2019 | 12:09 PM
  #48
C240-Merc's Avatar
I had the same set up, but I could not fix the caster angle so I decided to take the Thor springs off and just leave the shocks. I’m curious how did you correct the caster angle?
Old Nov 13, 2019 | 12:20 PM
  #49
Texas E63's Avatar
caster issues were the reason I used the 40mm spacers - along with keeping the ride / handling qualities of the AMG springs, given the HP of the 63....
been down that road many times chasing things on landcruiser builds when taking them past 1 1/2 - 2" of lift... often it leads to camber issues and vibration issues that lead to a rabbit hole of new replacement upgraded parts...
40mm seems to clear the 305's / 34 inch tires with full travel and room in the fenders.
Old Nov 14, 2019 | 02:23 AM
  #50
HtownG's Avatar
Yes I’m using the fox/Thor setup. And I did use the extended brake lines to be safe.
