Has anyone here lifted their G class?
My goal is a 2-4” lift with 33-35” tires, along with some G55/63 fender flares and a pair of VisionX Light Cannons (and maybe a light bar). However, like I said I’m hopelessly unaware of what to do, and was wondering if anyone with experience could help me out.
Thanks!
Yes, search a bit and there are quite a few threads.
2" is easy with spacers, and will allow you to run 35s, stock springs and shocks. You will need wheel spacers to avoid rubbing at full lock. 33s are best with 2" IMHO. I ran this for awhile on stock 18" wheels and it is a nice compromise. 35s just look like massive tires stuffed in there without more lift.
4" is also doable, but you will need to address caster (either by the trialing arm drop brackets, caster adjustable bushings, or revised trailing arms), and really should take a look at longer bodied shocks or at least ones capable of more travel. If not you will beat up the bumpstops on the factory shocks. This is easiest done with springs and spacers. Depending on the truck you may need extended brake lines; though this doesn't seem to be a real necessity as you don't have much articulation (And lose some with the spacers), it is a nice safe bet. Tires are the same story as above, but 35s look good.
More gets incredibly complex. I am 4.5-5" of actual suspension lift right now and it is on the edge of just about everything and has been quite a bit of a journey. 2" is cheap and easy, 4" gets dramatically more expensive. A few of the "4 inch lifts" listed out there don't really get you a full 4" of suspension lift. I have had to do mil spec trailing arm brackets, still add caster adjustable bushings, ORC extended brake and locker lines, and do quite a bit of fenagling. This is on top of the Thor springs, spring spacers (I actually went from 50mm to 40mm to make life a little easier), King external reservoir shocks. Looking back I may have just approached it a bit differently, but the trucks weren't really intended for this much suspension and thus it adds layers of concerns to address. I am currently on 20x10 35s, but will eventually be going to beadlocks and 16" 34.5" tires.
G63 fenders (I have now) definitely are a good idea with spaced wheels.
Thank you do much for the help.
P.S. Also...spacers vs new springs?
Are there road legal kits you know of with all the necessary hardware inclusive? I figured on using wheel spacers no matter what I did (as I like the wider stance). Do you know of any 33.6 - 34" tires that would fit on the stock 18" wheels? Are there any other parts I might need?
Lots of tire options, I would hop on tirerack or similar and poke around. The factory 18s will hold a wide variety of tire widths, but will depend on how wide the wheel is (I believe almost all the 18s are 8.5").
Spacers vs springs depends on how much you want to spend and end goal. Springs are the better option, but spacers work just fine for many.
If you go bigger you should get some different wheels with a lower offset or get some Wheel spacers to clear rubbing at full lock.
This link can show you a G55 AMG with 18 inches Brabus wheels and 305/60R18 (almost 32.5")
https://www.mercedes-fans.de/fotostr...ler.916.1.html
Thanks!
We're running a 3" lift on 33" tires and 30mm spacers with no rubbing issues. Please check out the link..Thanks!
https://mbworld.org/forums/g55-amg-w...s-g-wagon.html
Will175's truck looks like 2-3" of lift. Here is what 35x12.5r20s on almost 5" of lift looks like (some better angles for gap/fender fitment compared to what I posted previously)
each has different paths for a build IMHO...... what do you want to accomplish ?
I've built a few dozen offroad rigs, but the G's are very unique as to what works- and where the costs go pear-shape........
E
