2003 G500 Front Seat Heater Issue
Appreciate any help!
Edit: Not sure I understood your information when I posted the above paragraph. If you're saying that the fuse still blows when the seat controller is disconnected then the problem is between the fuse block and controller. The controller comprises a high current capacity switch - probably a relay - that is controlled by a low current activation switch. It seems unusual that a wrapped and secured cable would short out, but still possible. I would have suspected the controller to be at fault, if not the heater element.
Thanks for the suggestion. Yes, the fuse still blew immediately when I disconnected what I thought was the seat heater power. However, I will attempt your suggestion this afternoon with ALL the cables off both seats. I, too, am surprised a wiring harness would short out.
Another interesting thing is the driver's side electric headrest motor will not run when there is weight on the seat bottom. If I stand outside the car, the headrest will move properly. If I sit in the seat, the headrest will not run. I'm beginning to think something is being pinched in the driver's seat connections.
Again, thanks for the help. I'll let you know what I found later today. (Wife is driving the G-wagen right now!)
Thanks for any help!
Thanks again for the suggestions. I'll report the findings once I've done a bit of wiring archeology.
Looks like I have to pull the seats to chase the wire inch-by-inch looking for the short/chafed area. It will require a lot of carpet pulling and panel removal. Not really willing to do that myself so I'm dropping it at my independent repair shop tomorrow. Will update when I get the car back.
