Please Read. Emergency Situation - On Vacation Car Won't Start
Old Oct 16, 2021 | 10:29 PM
Gklassstyle23's Avatar
G63
2016 G550 34k miles. Was driving great.
Finished lunch and got in car and all of a sudden I was getting the following error message and constant beeping every 3 seconds "Release Parking Brake".
I never initiated the parking brake and it was not actually engaged because the car would roll from neutral. This continued even if I turned off the car. I was able to get to my destination (5 miles further down the road). Now a few hours later when I try to turn the car on...it won't even crank.
Lights come on and so does the AC but I am getting a ton of error messages:
LOW RANGE Malfunction To Park, Apply Brake
Front Right Malfunction Service Required
Blind Spot Assist Inoperative
SRS Malfunction Service Required
SOS Inoperative
I have never had these error messages until today after that Parking Brake Issue.
Your help is truly appreciated. I am guessing this is some sort of battery issue.
Old Oct 16, 2021 | 10:30 PM
G63
SOS Inoperative
Old Oct 16, 2021 | 11:55 PM
chassis's Avatar
2017 GLE350 4MATIC
Sounds like battery related.
The battery in a 2016 could be 6 years old now depending on build date. Time for a new one, plus aux battery if there is one.
Old Oct 17, 2021 | 01:06 AM
E55Greasemonkey's Avatar
This place is a joke.
Has it been raining a lot? Could be water under the carpets from a leak. Hopefully there's an MB dealer close by you can tow it to.
Old Oct 17, 2021 | 01:07 AM
RossoLinea's Avatar
2008 G500
Sounds like a failed battery. Most auto parts stores can check load easily. Five years old is reasonable for battery life.
Old Oct 17, 2021 | 02:04 AM
G63
No rain...90 plus degree weather. This all happened within a 4 hour period.
Old Oct 17, 2021 | 02:06 AM
G63
I'm thinking you may be correct....I am hearing there is a main battery as well as an auxillary battery. Anyone else had this issue? Literally every system is malfunctioning and the car won't turn on.
Old Oct 17, 2021 | 03:29 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Errors super combo....
it seems like a collection of your computers modules (ECU & SAMs) have gotten temporarily disrupted. This is frequently caused by low voltage ... but there are a hand full of different problems that can produce that glitchy condition, including battery troubles.
Temporary fix:
  • ​​​​​​Charge your batteries (with a CTEK...)
  • then disconnect Batts for 15mn
  • then hook 'em back in
  • Scan you car to gain insight.
No crank is a royal pain... but it trumps getting into limp mode in highway traffic.✌️
Old Oct 17, 2021 | 03:55 AM
G63
Any other ideas? Since I am basically stranded (need to drive back home on Tuesday), don't want to be at the mercy of a dealer so far away from home. I am planning to buy both an auxillary and main battery tomorrow and replace. If this fixes the issue...could it still be a bad alternator? Again this all happened at once.
Am I going down the wrong rabbit hole?
Old Oct 17, 2021 | 07:52 AM
The Butcher's Avatar
G63, G65
Sounds like a bad battery to me as well. More than likely just the main battery. Try and swap in a new one and see if that solves the problem.
Old Oct 17, 2021 | 09:48 AM
streborx's Avatar
Top Answer: 1
G550
All this OBD technology, but not a simple annunciation that tells you "Low Battery - 10.6V". Instead, you get entertained by a scary Halloween light show convincing you that you're experiencing a major ECU China Syndrome. Let us know the prognosis.
Old Oct 17, 2021 | 10:42 AM
only you decide how to spend your green cash without any testing... a new Alternator and Batteries can't hurt, these are maintenance items.
Drive with Headlights:ON will lock the alternator output to 13.5v Min... that is cheap insurance against low voltage ⚡
Google the procedure to display your car Voltage on the cluster with "Engineering Menu". This will show you Amps/Volts being produced and used.
Old Oct 17, 2021 | 10:44 AM
chassis's Avatar
2017 GLE350 4MATIC
If it were my car, I would replace both batteries. They are overdue and are part of regular maintenance. If you plan to keep the car more than 2 months from today, the batteries need replaced.
Old Oct 17, 2021 | 11:05 AM
very true!
all this managed chaos... and this is suposed to be "the Best or Nothing"
even the simple Alternator gauge is now a hidden display option 😜
Old Oct 17, 2021 | 12:24 PM
G63
Both auxillary and main battery changed. No improvement. Still getting same error messages and no crank.
Old Oct 17, 2021 | 12:26 PM
G63
Old Oct 17, 2021 | 12:44 PM
RossoLinea's Avatar
2008 G500
The battery can be charged but still not have the amperage to crank the engine. I just replaced my 5 year old battery this week and it would charge and show 12 volts but would not crank. Did you have the battery load tested?
Old Oct 17, 2021 | 01:03 PM
G63
I changed the batteries so battery can't be the issue. How would I check the battery load. I have limited supplies with me. I did connect a jump start device as well when the new batteries were in..still no improvement. No crank and all the error messages listed above.
Once again all of this started yesterday with the faulty "release parking break message"....then proceeded to car not turning on with all the other error messages.
Could it be a fuse?
Alternator?
Anyone had this before?
Old Oct 17, 2021 | 02:30 PM
streborx's Avatar
Top Answer: 1
G550
Could it be a fuse?
Alternator?
A new off-the-shelf battery should have enough charge to crank the engine, even if not fully charged. I assume you've checked the owners manual section on the parking brake operation -- is yours electric? You might check the starter fuse and relay, but it seems unlikely these would be at fault given the symptoms you've listed. There are so many goofy safety interlocks that try to shield you from injury, you end up with injuries trying to troubleshoot them.
Many errors + NO crank...
You have so many errors that it's unlikely the usual transmission ISM shifter or Brake Switch issue... then try bypassing KeylessG by inserting KEY in ignition.
Scan your modules to get your list of DTC Faults and pick from there🤞
Old Oct 17, 2021 | 03:47 PM
G63
2016 doesn't have the button start...always uses the key.
Old Oct 17, 2021 | 03:49 PM
G63
Manual parking brake. Never engaged. It literally went from one fault message "release parking brake"....to not turning on with tons of fault messages.
Old Oct 17, 2021 | 04:59 PM
streborx's Avatar
Top Answer: 1
G550
If you can make your way to an auto store (Autozone, O'Reilly, Napa, etc.) you can borrow an OBDII scanner and maybe get some error codes that make sense, and/or reset them and see what happens.
Old Oct 17, 2021 | 05:19 PM
G63
Unfortunately I can't get my car to autozone and already have 2 scanners at home....don't want to add a third. Need to start carrying them in the car.
Old Oct 17, 2021 | 05:51 PM
Quick bush-fix...
While you're stranded away from your tools...
1- You can try to tip-tap around gently (prefuse module, SAM modules, Ignition Key module, driver footwell, passenger footwell...) while you have someone hold the ignition key in crank position - This might very well wake up a flaky relay and a bad ground screw with oxidized contacts... nothing to loose. I'd concentrate on what's switching heavy DC power.
2- Next you can physically check if you got water intrusion (SAM'S enclosures, footwell carpets..)
3- Disconnect both batteries at once for 10+Mn then reconnect MAIN followed by AUX.
