Biggest tire size for stock wheels
Old Nov 14, 2021 | 08:46 AM
ash0468's Avatar
2019 Mercedes Benz G63
Hi team,
just looking for recommendations for the biggest tire size for a stock 2014 G63 amg.
Looking to get a beefier look.
275/50/20 stock size
stock size is 275/50/20.
what is the biggest size I can put in without rubbing the sidewalls .
thanks
Old Nov 14, 2021 | 04:50 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
I (think) 32" is about as tall as you can go without a lift or spacers.
Old Nov 15, 2021 | 12:15 PM
Lhommec13's Avatar
2006 G500
Not saying it's the largest, but I have 275/55/20 (31.9") without any rub. You could probably still go a bit larger.
Old Nov 16, 2021 | 12:41 AM
z168's Avatar
3phase-4pole
Looks awesome. Hows the road noise on those?
Old Nov 16, 2021 | 12:12 PM
Lhommec13's Avatar
2006 G500
I've only ever driven the G on some form of MT or AT tire. I bought it with Toyo Open Country MT and it was very loud, as in obnoxiously loud. So I switched them out for the KO2's which I've had on several trucks before the G. It's my AT tire of choice and very versatile for all conditions.
Old Nov 16, 2021 | 01:16 PM
bokonon's Avatar
2006 G500, 1988 VW Vanagon, 2003 M5
My 2006 G500 has 18" and tire rack doesn't list K02s in the proper size. What do people with 18" wheels run?
Old Nov 16, 2021 | 09:20 PM
shiann's Avatar
2005 G55K
The KO2's are pretty quiet overall on the highway and are usually drowned out by wind and exhaust noise. I've had KO2's on my G55 for ~18k miles now and they've been great. Much quieter than the old Pirelli Scorpion Zero tires I had on there that had plenty of tread left, but were dated early 2012.
I'm running them in 285/60R18 which is a 31.5" tire. Plenty of room on OE G63 springs and no wheel spacers. You can probably get away with upsizing slightly without any issues.
For reference:
18" Tires
265/60R18 = 30.5"
265/65R18 = 31.5"
265/70R18 = 32.6"
275/65R18 = 32.1"
275/70R18 = 33.2"
285/60R18 = 31.5"
285/65R18 = 32.6"
20" Tires
265/60R20 = 32.5"
275/55R20 = 31.9"
275/60R20 = 33.0"
275/65R20 = 34.1"
285/55R20 = 32.3"
285/60R20 = 33.5"
Old Nov 17, 2021 | 12:41 AM
z168's Avatar
3phase-4pole
Got it. Do you mind posting a side profile of your G so I can see the proportions of the tire wall? Thanks
Old Nov 17, 2021 | 12:42 AM
z168's Avatar
3phase-4pole
Thanks for the input. Mine will be due soon. I may go this route with the tires. Having Advan tires on the G just looks wrong
Old Nov 17, 2021 | 06:29 PM
JD101b's Avatar
(Sorry, this was posted in error)
Old Nov 17, 2021 | 10:09 PM
nt927's Avatar
G
We've run 275/55R20 on our G63 and G65 with no issues. First set was BFG KO2, current set is General Grabber ATX (which have much better manners than the KO2s on-road and in the rain)
Old Nov 21, 2021 | 01:00 AM
ash0468's Avatar
thanks.. just how I bought it- hence the change. Thanks
Old Nov 21, 2021 | 05:59 AM
DVR's Avatar
DVR
2016 AMG G63 (W463)
Bokonon
I have a 2016 G63 but have purchased 18" rims (Alpha) from Jacks Overlander. On these I am running 265/65/R18 as I do a lot of offroading. I have just finished a 22,000 km treak across Australia and they perfromed well across multiple tgerrain types. The higher profile tyre enables you to deflate for sand and mud so they deliver on purpose as opposed to looking 'aggressive',
David
Old Nov 21, 2021 | 03:47 PM
z168's Avatar
3phase-4pole
sorry that wasnt a dig on you. I have Advan tires too. They are OEM tires for the G
Old Dec 11, 2021 | 05:23 PM
2016-AMG-G63's Avatar
2016 AMG G63
Originally Posted by DVR
Bokonon
David
Hi David, I have a 2016 G63 AMG and I’m interested in a new set of tires and wheels, as I also plan to do as much off road as possible. Would you mind sharing your wheel and tire selection?
Old Dec 12, 2021 | 03:54 AM
DVR's Avatar
DVR
2016 AMG G63 (W463)
I am running BFG All Terrains on an 18" rim provided by Jacks Overlander. The tyres are 265/65/R18. In hindsight I would get 285/60/R18 as the side profile is virtually identical which means you can deflate for sand and mud but the 265's look a little 'skinny' on the G wagon (refer p[hoto) . On my recent trip we did an iconic Australian road called the Gibb River Road. 660km of gravel with a reputation for destroying cars and tyres. Interestingly, there is a tyre repair guy midway along this road and he will only install BFG's. They handled any terrain we threw at it and they perfromed well. That said, they are not as good as the OE tyres on the bitumen.
Hope that helps
[img]https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/w463_copy_d11edc3c4e26bb20ce8025e528116f2828fb0d7b .jpg
Old Dec 12, 2021 | 11:21 AM
z168's Avatar
3phase-4pole
fixing link
Old Jan 9, 2022 | 02:53 PM
G550noob's Avatar
G550 2012
OWN
G550 2012
running OEM 20” G63 Wheels
would a 305/50R20 fit without rubbing (with or without spacer)? Going for lower height but wider tires to stick out from fender (does not need to be much). Or do you recommend 295/50R20 and run spacers? Ive seen another gwagon run 305 but not sure how much it rubs (if any)
Wheels i have
Old Jan 9, 2022 | 05:39 PM
Minoclan's Avatar
G63
I have the same setup with 31mm spacers. It seems like the best solution.
Old Jan 9, 2022 | 06:17 PM
G550noob's Avatar
G550 2012
thanks. I am currently running your setup with road tires and they only barely align with fendors. Im more interested in the wider tires.
Old Sep 27, 2022 | 07:15 AM
Scotland@123's Avatar
G350
Hi There .. new to the forum and looking for the tyre set up in your pic as im looking to get AT3s for my G500. Many Thanks
Old Sep 27, 2022 | 07:16 AM
G350
Originally Posted by G550noob
OWN
G550 2012
Wheels i have
​​​​​​Hi There .. new to the forum and looking for the tyre set up in your pic as im looking to get AT3s for my G500. Many Thanks
Old Sep 27, 2022 | 12:34 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
305's fit nicely with a 31mm spacer
325's fit if you get the offset of a new rim right.... 18x9.5 et25 seems to work well...
G63 on 305's not lift
G55 - 2" lift and 325s'
Old Sep 29, 2022 | 05:13 AM
G350
So pic 1 is Grabber AT3s im guessing & Whats the size (305 55 20 ) .?
Old Sep 29, 2022 | 08:02 AM
Texas E63's Avatar
All pics of the 63 are Toyo At2's( 305/55/20) - the 55 is running At3's (325/60/18), the III provides a decent improvement, and a bit smoother rolling casing it seems...
E
